ok i have a .avi file, that is 792 mb, any way to burn it in a 700 mb cd? I heard one time that you can force it but I dont remember well, no is not a vcd or something, is just a .avi in a cd
thank you
As is, I don't think so. There's overburn features on some burning software but results will vary for that. If your just trying to store the video try zipping it.
I don't think zipping will help much. VCD uses mode 2 burning which drops the error correction bit, giving you 800 MB. I believe I heard of a utility that can burn in mode 2 with data files, of course you stand the chance of producing an error if you copy back off the disk. Try a search on mode 2 burning.
"Art is making something out of nothing and selling it." - Frank Zappa -
Hello,
Either reencode it to fit the 700mb disc or check ebay or other online marketplaces for 99 minute cdr's
(though they won't work in ALL standalone players but will work on the pc/mac platform
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Burning AVI to DVD - AVI not viewable
By Budfudder in forum Video ConversionReplies: 8Last Post: 24th Mar 2011, 10:36 -
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 13:09 -
Burning .avi to DVD
By monieeka in forum MacReplies: 6Last Post: 12th Sep 2008, 07:40 -
Burning .avi files
By pilgrim02 in forum MacReplies: 13Last Post: 31st Jul 2007, 12:52 -
AVI to DVD Burning
By DVDHelpPlease in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2007, 00:38
