hey i need some help converting a divx to vcd
the size of the divx 613MB....i tried converting it to vcd and it came out to 850 megs...i downsampled the sound to 192K (from 224K)
i tried using it as CQ_VB and it came out to 830 megs....
its a 2 part divx so when i encode both to vcd it come out to almost 1.7 gigz (too big for 2 cds)
is there a way to get it smaller without sacrifising quality (the quality of the divx is average, nothing great, but not too crappy)
thanks
That's your prob, with VCD spec settings and 80Min CD can hold 80min of video (ignore the Mb space when doing VCD). You could try to overburn or use 90min media.
converting Divx to QT?
By rotuts in forum MacReplies: 3Last Post: 17th Jul 2008, 17:28 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
Converting DivX to HD
By CFCproductions in forum Video ConversionReplies: 6Last Post: 18th Jan 2008, 15:11 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54
