Does anyone know of a program that will let me batch author (except for gui for dvdauthor - too bugy and not user-friendly enough). I don't want any quality loss and I don't need menus. My process to create dvds is as such (I have about sixty to do..........:
1.) Load mpgs or avis in Main Concept (best all around encoder because its real time and allows for batch encoding.
2.) Author with Tmpgenc Author
3.) Shrink down with dvdshrink (2-Pass)
Any help will be greatly appreciated. I don't want to change the fact that I use Main Concept.
Results 1 to 17 of 17
Nothing is impossible for DiLeMmA says so!
See my guide on how to batch author dvds!
https://www.videohelp.com/forum/viewtopic.php?t=255213 -
Since you want simple DVDs without any menus, my guess is that each one will contain a full length title (movie or long clip), long enough to justify a whole DVD.
As such, you can skip step 3 of your process - which only takes time and reduces quality - by spending a few moments to select a proper bitrate for encoding at step 1.
4800kbps will fit 2 hours on a DVD while 9600 will fit 1 hour (very rough indications). Use a bitrate calculator for precice calculations.
Other than that, once you finish the encoding you will end up with a pair of video and audio streams (or a single file - depending on your settings).
DVD Lab or IFOEdit are two choices for authoring the DVD, but don't know of any means to automate this.The more I learn, the more I come to realize how little it is I know. -
Your best bet would be to learn to use dvdauthor natively (without any gui). Since you do not require menus, batch operation would be simple. A pre-canned XML is all that would be needed. Something like this:
then, simply run dvdauthor -x config.xmlCode:<dvdauthor dest="c:\dvd"> <vmgm /> <titleset> <titles> <pgc> <vob file="video.mpg" /> </pgc> </titles> </titleset> </dvdauthor>
The 'video.mpg' will need to be a dvd compliant file, which can be generated with mplex if needed. The output will output to a folder named 'dvd' which should be created on your C drive prior to running that command. -
Ok...thanks a lot guys. Now I have a second question. I decided to use gui for dvd author since I can just drag and drop. Now basically what I did is this:
I would drag one half of the movie to the main screen and then the second half to the main screen. I then create a batch in a folder that i already created for that movie. After that I closed the program and then did the same for the second movie with its own folder (two different movies separate folders with its own mainbatch.bat).
Now what I need to know is this: How do I create another batch file that will call all of this batch files in order and wait for them to finish until it calls the next mainbatch.bat file. I tried this by typing this:
What happened was a screen flashed for a couple seconds and nothing was done......huh!!! Any help will be greatly appreciated. Thanks again for the quick repliesCode:call c:\myflick1\mainbatch.bat call c:\myflick2\mainbatch.bat call c:\myflick3\mainbatch.bat
The commands within the batchfiles called by the mainbatch.bat need to be processed form their directory (they have no full path). Therefore just create your batch file (let's name it callall.bat) like this:
Put the callall.bat in c:\ (assuming the above directory structure)Code:cd myflick1 call mainbatch.bat cd.. cd myflick2 call mainbatch.bat cd.. cd myflick3 call mainbatch.bat cd..
Open a command console on c:\ and run the callall.bat from there. -
Thx a lot borax. Now I can batch author. GREAT!!!! Now all I have to figure out now is how to make one continuous track from two mpegs without using a menu......
Remark:
If you use the new version (>0.80) the logic is changed a little bit (as GFD now uses a temp directory for all files created by "Create Batch". Have a look to the doku:
https://www.videohelp.com/~gfd/GUI_DVDauthor_eng_07.htm#Batch_ProcessingGUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I would suggest that we make this a sticky or a guide of some sort. This was not that easy to figure out......at least in my opinion.
If you write the guide, I will include it on the GFD homepage. But it would be the best if you would write the guide...
For me as the writer of the program, a lot of things are "absolutely clear" and don't need a description at all. For the user it may be quite different...GUI for dvdauthor:
Will Do. I'll look at the other guides to get an idea of how to write one.
I just wrote my guide. Check it out..........https://www.videohelp.com/forum/viewtopic.php?t=255213&sid=9a5ebeb4017bb11423c0a65724d6497dOriginally Posted by borax
Also, what programming language did you use to write gfd?Nothing is impossible for DiLeMmA says so!
Very nice guide!
Some points should be discussed:
1. This guide is only valid for GFD versions < 0.82
=> We/you should either create another one for the newer version (ATM 0.83) or rework it (correct setting of the temp directory!).
2. In the old version was a bug within the video file dialog which caused a wrong interpretation of the file type if more than one point was in the filename like: your.movie.file.mpg (this bug also caused problems with blanks in the filename)
This bug is now corrected.GUI for dvdauthor:
Would that suffice?Originally Posted by dilemmaNothing is impossible for DiLeMmA says so!
No, I don't think so... Because also the batch file has to be set up in another way (it has to point to the temp directories)
GUI for dvdauthor:
Originally Posted by dILEMMA
iS THAT ok?Nothing is impossible for DiLeMmA says so!
Your welcome to put it on your website if you want. Although, I think the guide that is there is quite sufficiant. The problem is people don't invest the time to read it.
FREEWARE for batch, menu-less authoring of DVDs
By nharikrishna in forum Authoring (DVD)Replies: 6Last Post: 11th Oct 2011, 04:00 -
AC-3 and Wave 5.1 frustration revisited...
By takearushfan in forum AudioReplies: 32Last Post: 19th Aug 2010, 13:54 -
MTS2AVI revisited
By RogerTango in forum Video ConversionReplies: 35Last Post: 28th Jun 2010, 16:08 -
Blank media revisited
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2008, 09:57 -
DVD Authoring software with Batch author?
By love2learn in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2007, 09:20
