Visit the Homepage of AutoQ
AutoQ will get You the right Q-Value. So You can do One-Pass-Encodes
with CCE.
I support Windows 2000 SP4 & Windows XP SP1/SP2. I didn't tested Win9x & WinME. With this OSs You may have problems using my tool!
Features of Version 1.2.5:
Supports CCE SP Trial 2.50 - 2.70.01.05
Also supports CCE SP 2.70
Coded for Windows 2000 & WinXP
Custom Matrices can be used
Auto-Reload the settings of the last-run
User can save his settings
Importing of AVISynth-Scripts
Chapters import
Debug-Mode
Logs saveable
CPU Priority selectable
DVD & SVCD support
Abort-Function
Safemode
Language editable
2 different Predictionmodes
Releases:
Build 1.2.5: Added: Amnon Prediction (Version 0.2)
Build 1.2.4: Fixed: Predicition-Calculation changed.
Build 1.2.3: Changed: Sample will be encoded as 3rd SameQ-Run.
Build 1.2.2: Added: Support for CCE 2.50
Download AutoQ V. 1.2.5
I've just posted a guide over in the forum guides explaining how to use CCE's OPV to achieve optimal bitratres for encoding (using any encoder)...
https://www.videohelp.com/forum/viewforum.php?f=15
Authoring Software that supports h.264
By sampalmer21 in forum Authoring (Blu-ray)Replies: 1Last Post: 3rd Nov 2009, 10:17 -
If Flash now supports H.264. . .
By sdsumike619 in forum Video ConversionReplies: 18Last Post: 5th Aug 2009, 15:28 -
Supports .srt subs? Or not?
By Tabula Rasa in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 13th Aug 2008, 13:00 -
Adobe Flash now supports H.264
By lordsmurf in forum Latest Video NewsReplies: 0Last Post: 4th Dec 2007, 12:08 -
DVD player that supports GMC?
By perdomot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Nov 2007, 18:38
