When I use my DVD +R discs in my set-top DVD recorder I can add more to it until it's full. For example, I can record a 1 hr show then later on record another 1 hr show.
With my DVD writer (computer) once I add something to the DVD +R (like an authored video) it will no longer accept any more videos, even if it is less than half used (1-2 gb used max.). Is there a way to change setting when burning to allow me to add more to the DVD later on?
Same question with +RW discs - I don't seem to be able to add on to one, just erase and write to the blank disc. Ant way to keep what's on there and add more?
Hello,
Just don't FINALIZE the disc until you're done. FINALIZING makes it full and unable to be added to.
Though a RW can be erased obviously
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Adding controls to a swf (then adding to website)
By AshleyQuick in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2011, 04:02 -
Need help adding a subtitle to a DVD.
By chris4556 in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2011, 22:12 -
adding clip to DVD
By pcb in forum Authoring (DVD)Replies: 2Last Post: 26th Apr 2010, 16:00 -
adding subtitles to a dvd-r
By nicgrosso in forum ffmpegX general discussionReplies: 4Last Post: 1st Feb 2008, 13:49 -
Adding subtitles to a DVD
By RealTelstar in forum SubtitleReplies: 2Last Post: 28th Sep 2007, 15:35
