I need some help on this DVD Recorder. It will never display tapes right, but it will display the satilite perfectly. The tapes that I play that go out to the DVD Recorder are always to bright and sometimes flicker in contrast and brightness. Does anyone know what the problem could be?
I have it away from other electronic devices, I bought a new A/V cord, I have it so that air can get to the bottom of it, and I have tried a factory reset.
There was a patch for vcr's for the 9000's, maybe yours needs a firmware update?
Sounds like copy protection.
https://www.videohelp.com/forum/viewtopic.php?t=246129Want my help? Ask here! (not via PM!)
lordsmurf, it sounds like it is probably that. I know that the VHS is not copy protected because I am the one who recorded it. I will be looking around for a "remover" or "enhancer" device. Thanks lordsmurf
I will probably get the one here: http://www.checkhere22.com/stabilizer.html . It sounds like it would be a good one. And thanks thanks again lordsmurf, I was about to go
at the company because I thought that the DVD Recorder was going bad
Weird component problem with LG555 and Apex tv...
By dvd mon in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Jan 2011, 14:40 -
Crown ADVDR9000 (Apex DRX-9000 I Think...) Firmware.
By eufemia in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Apr 2009, 10:01 -
Replacement for Apex AD-1500
By siskiou in forum DVD & Blu-ray PlayersReplies: 7Last Post: 30th Mar 2008, 22:59 -
Apex AD1250X Owners?
By nemesys23 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 17:36 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 11:33
