I am sure that VCD files are much smaller than DVD files. And I know around 2 hours of film can go on a DVD in the DVD format. So I'm just wondering how much more film can you put on a DVD in the VCD format for standalone DVD players of course.
Results 1 to 12 of 12
8.5, maybe 9. Most I've ever got was just over 8 hours before I couldn't see wasting a blank on something that looked so crappy.
Last time I did this I was recording the stuff on all the different news channels as I flipped back and forth between them all night durring the presidential election. Got just over 8 hours on a DVD before it started looking like less than VHS quality."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Wow, that's great. I have lots of old videos I need to get on DVD and there is no sense in formatting a video in DVD quality anyway since I don't think you can get better than the original. Thanks.
I wouldn't put more than 3.5 to 4 tops for anything I really cared about, and it would be MPEG2, not VCD (MPEG1). My example was in the extreme....just experimenting really. That was 8 hours of video capped under the best conditions, converted to progressive scan (23.976 fps) and it was really pushing it quality-wise.
Just to clear up some confusion. DVD has three basic resolutions; full, 1/2 and 1/4 DVD. All three resolutions are "DVD format." You can use any bitrate that you wish for any of the resolutions and it's the bitrate that determines the number of minutes on a disk. To keep the video looking good you will need to increase the bitrate as the resolution is increased...it's the number of bits per pixel that matters. So I use 1/4 DVD for less than 1,6000 kbps, 1/2 DVD for 1,600 to 3,200, full DVD for >3,200. I always use 2-pass VBR when I'm at the low end of the range.Originally Posted by johnharlin
VCD resolution just happens to be the same as 1/4 DVD so it can be put straight to DVD. Assuming the VCD standard 1150 kbps bitrate you can get about 420 minutes on a DVD, or about 7 hours. Of course you can lower the bitrate (like sacajaweeda) and get even more."Art is making something out of nothing and selling it." - Frank Zappa -
About 20 hours+ in the very extreme using mpeg2.Originally Posted by ZippyP.
Use the KSVCD or KDVD templates, and get 16-20 hours on one dvdr. Don't expect miracles.
Cheers, Jim
My DVDLab Guides -
do you have to upsample the audio to 48khz or something like that?
when I try to put a fully compliant vcd video on a dvd using tmpenc dvd author it tells me that the GOP is too long, what does it mean exactly?
thank you -
Hello,Originally Posted by mariogarcia
Yes the audio does have to be 48khz but tmpgenc dvd author SHOULD convert it for you and leave the video the same.
Try the "ignore" button for the GOP error and see if it plays, I suspect it will.
Another program for 6 hours on 1 DVD
By Torben in forum Authoring (DVD)Replies: 7Last Post: 14th May 2010, 12:10 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 23:40 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23 -
fitting four hours on 4.7 GB DVD
By cthiesen in forum Newbie / General discussionsReplies: 34Last Post: 13th Apr 2008, 17:36 -
trying to put VCD files on a DVD with MyDVD Express
By curt1sw in forum Authoring (DVD)Replies: 7Last Post: 15th Nov 2007, 15:42
