hi,
ive been using premiere pro for a few months now, and have been exporting to dvd without a problem till now, it is asking me to activate the mpeg encoder by phone or internet, and i cant understand why the program is doing this as ive had it installed and running for months now?..
your help is much appreciated
mixa
As long as it is a legit copy, then activate.
There is no harm. -
They do this every so often. If on internet just push the button.
cheers its working now, they must to this every so often to disable pirate versions of premiere
thanks
mixa
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 17:10 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 21:48
