  1. Hi,
    I'm using a Hauppauge WinTV PVR USB2 connected to the S-Video and Audio outs on my Sky+ box.
    I'm recording using the Hauppauge software to capture to MPEG1 VCD. I then covert the VCD to XviD using VirtualDub.
    I play the converted file back and the audio/video is always out of sync
    Any ideas?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    There's an audio skew check option in virtualdub. It lets you correct audio synch issues.
    As for why I don't know - I don't do divx/xvid much...
    Kevin
