    Jul 2003
    hi,
    i have an .avi file i would like to change to a mpeg file, however as soon as i encode the file, the sound is out of sync.
    i tried encoding the file with dr.divx and tmpegnc but the results are the same.
    i have pulled the sound from the video as the encoder crashes if i use the .avi file for sound as well as motion.
    if i play the .avi file it works fine with the sound in perfect sync.
    anyone know how i can get around this.
    Apr 2002
    The State of Frustration
    Load the video into Gold Wave, and save it as a wave file. Then try encoding using both the video file and the new audio file.
    Hello.
  3. Banned
    Oct 2003
    Americas
    If you happen to own NeroVision (check Nero.com) you may try "make DVD"->add video file->export video (select mpeg compression level).
    Very good for avi to mpeg.
