Do DVD RWs lose quality with repeated use if you are using them to transfer video to the computer?
Hello,
I don't believe so - when it can't write anymore it will just cease to function. It won't degrade like vhs
Though I still don't know what the practical real world limit is on rw discs - they say something like a thousand uses.....
I've had some Memorex discs go squirrelly after as little as 10 passes. Others have reported less. Usually you can get them going again if you can reformat them in your computer though I've had some programs reject them for reformatting as well. One of the old versions of Sonic Record Now Deluxe (version 7, I think) seems to be able to do it all the time though, so I use that. I've been gradually getting rid of those Memorex discs in favor of DVD-RAM which I've never experienced a format problem in over 16 months of use.
Be sure to handle all media carefully. Dust, fingerprint, scratches, etc. can have a determental effect. If necessary clean them as per the maufactorers instructions
Phase change is unstable. No surprise. Most often, you'll see "spots" (like mini craters) form in the crystals. Can happen even on old, but unused media. 10,000 rewrites is a pipe dream. Several dozen, maybe several hundred, is probably the limit on many of them, at least according to reliable user reports. And the better media you buy, the longer it should last.
Most of the 2x RW media seems better than the 1x too, in terms of quality (although my SONY RW are fine).Want my help? Ask here! (not via PM!)
I've had 5 Fuji DVD-RW's for about 2 years now repeated use, each still goin strong
Repeated burning error with dvd flick :(
By Akhet in forum Newbie / General discussionsReplies: 24Last Post: 6th Apr 2016, 08:45 -
Ripping PAUL DVD has repeated scenes
By sulu98 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 4th Sep 2011, 09:42 -
Quality degradation from copying mp3's
By SE14man in forum Newbie / General discussionsReplies: 13Last Post: 31st Aug 2010, 05:53 -
question about repeated DVD burn failure at about 90%
By jimdagys in forum Newbie / General discussionsReplies: 18Last Post: 18th Mar 2008, 21:34 -
Letterbox to Anamorphic with as little quality degradation as possible?
By beatchef in forum Authoring (DVD)Replies: 16Last Post: 5th Feb 2008, 01:10
