Does somebody know a freeware software which can convert a Homevideo made on DVD in Pal system to a NTSC DVD in good quality?
Graphic Designer from Denmark
Hello,
May not work for you but if you have a xbox and a capture card you can "SOFTMOD" the xbox to play any dvd. Then simply play the dvd and record onto the capture card.
Works perfectly as I just finished a test run. For "SOFTMOD" tips visit www.xbox-scene.com for more details (don't play xbox live while softmodded or you will be banned - simply uninstall it and play your original games on LIVE with no problems
Kevin
(for software solutions check the guides to the left <----- look up "PAL TO NTSC"
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
PAL to NTSC conversion is very complex and, in most cases, simply not worth it. Most DVD players can cope with both so just leave it as it is.
Hello,Originally Posted by Richard_G
Not older US made dvd players
Hi koburg,
you have to encode the PAL video to NTSC video. You can use TMPGEnc encoder or WinAVI converter or Super DVD Ripper. All these software can very easily convert PAL to NTSC or vice versa.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
HELP: PAL to NTSC conversion
By hydrophonicaudio in forum ffmpegX general discussionReplies: 5Last Post: 15th Jul 2007, 09:24
