  1. Just found out that for TDA and AC3 plug-in one must have internet connection for occasional license verification. The computer I do my audio and video on has never seen nor will ever see the internet. I'm cool that I can't use TDA for authoring but now, what will I use to convert my audio to AC3?
    On a second note, I posted here earlier this week about encoding the video seperate from the audio (since TMPGEnc 2.5 Plus is not the best audio encoder out there). Someone responded that when I sent the encoded video over to the authoring software, all I had to do was also send the audio over to rejoin the two. My quesion(s): If I send the audio over as .wav file (16 bit, 48,000 htz, cleaned up and maximized in Adobe Audition) will this work or do I physically need to encode (or) compress the file before sending it over?
    My second question is, will this work in NeroVisionExpress? Can I just add the encoded video/audio in NVE and it rejoin the two?
    Thanks for your help.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You can still author ac3 without the plug in in tmgpenc dvd author - you just won't get sound in the preview.
    If you take say a trailer off a dvd thats in 5.1 and load the vob in tmpgenc dvd author you'll end up with a dvd that has 5.1 in it. You just can't edit it in TDA without the plug in that's all....
    Kevin
  3. Originally Posted by yoda313
    Hello,
    Kevin
    I'm going from video through a Canopus 100 into the computer >> capture with NeroVisionExpress (type 2) or WinDV or Adobe Premiere >> edit in Premiere >> encode in Premiere (which automatically only encodes the video, at least in my experience) or in TMPGEnc 2.5 Plus (Elementary Stream) >> author in NeroVisionExpress. In other words, the audio is never converted to AC3... right?
