I'm trying to convert an AC3 PAL file to AC3 NTSC. So I downloaded AC3Machine to use with BeSweet and I followed Doom9's guide on how to use it, but nothing is happening. The DOS window pops up for a split second and then nothing. I checked Output to Log File to see if it would show any errors, but nothing showed up there either. And yes, I do have AC3Machine pointing to c:\program files\BeSweet\BeSweet.exe. Can anyone help me out here? I'm sure this has been asked way too many times anyway, sorry if you guys tire of answering.
Okay, I figured out the problem. Turns out I didn't have the ac3enc.dll file. It now works fine. Although my output had a lot of popping and snapping in the background, anyone know how to fix that?
try the latest HeadAC3 Version (with modded ac3enc.dll)
Plz give feedback!
bye Daphy
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
How to Convert AVI to DVD + AC3 with CCE and AC3Machine
By ta2 in forum User guidesReplies: 40Last Post: 21st Jan 2010, 19:01 -
No Dolby Pro Logic from AC3Machine
By jonghyunchung in forum AudioReplies: 9Last Post: 28th Jan 2009, 15:35 -
Problems With AC3Machine
By jonghyunchung in forum AudioReplies: 2Last Post: 24th Aug 2008, 16:36 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11
