I am using Rejig to compress Mpgs that are larger than 2 hours to fit on one DVD-R. I am having a problem with the Audio/Video out of sync when I burn the DVD and play it in my player. Here are the steps to Compress the files, please let me know if I am doing something wrong or if I should use other tools to do the same job
mpg file duration 2:22 min
- I Open TmpGenc -> Mpeg Tools -> Simple De-Multiplex to get a video and audio files
- I open Rejig and open the Video file(.m2v) to compress at 95%
- I use TmpGenc again -> Mpeg Tools - Simple Multiplex to group the audio and compressed video into a single Mpeg file
- I use Nero to encode that Mpeg file into DVD-R format
Both audio and video are out of syn after 15 min of running the movie, can you please help
Thanks a lot, any comments about the steps I am using, are they ok or am I doing something wrong
can you give me some tips on how to use DVD Shrink.
A/V sync problem when remuxing (AverMedia mpg file)
By matomato13 in forum Video ConversionReplies: 8Last Post: 25th Mar 2011, 21:48 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
2875 x 768 px mpg compression?
By pisosse in forum Video ConversionReplies: 5Last Post: 8th Jul 2009, 00:29 -
Sorenson Squeeze compression causes sound to be not in sync with video
By psaad in forum Video Streaming DownloadingReplies: 8Last Post: 23rd May 2008, 14:53 -
Out of sync Audio; Video Compression?
By Thortok2000 in forum Newbie / General discussionsReplies: 8Last Post: 10th Aug 2007, 11:16
