    Jul 2001
    mobile, alabama
    after all editing is done--what program can i use to get a avi file back to the camera on tape? is this possible at all?
  2. You need a TV Out or a VGA -> TV converter which you connect with your tape recoder and play your edited file with any player and fullscreen.
    I am not sure but I heard that it is possible to copy with fireware cards directly the edited dv into the digital camcoder. I can't tell you how it works because I haven't a digital camcoder.
    CU,
    Michael
  3. If you are using a DV camera with firewire card:-
    Sonic foundry's Video Capture (supplied with Vegas Video) has a function to print to tape which transfers an AVI digitally back to your DV camcorder.
    BUT I havn't managed to get it working yet
