  1. I have a convertx m402u from plextor which makes mpegs from my old VHS tapes.. The problem is , I can not find any good software to quickly add a menu and chapters about every ten mintues and burn to dvd. Do you have any suggestions. DVD lab is about as close as I have come, but it is a little combersome to author with...I have tried all the other majors (ulead, dvd creator, etc). None have a simple chapter creator that looks nice..
    any suggestions?
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    TMPGENC DVD Author. It's as simple or complex as you need it to be.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  3. Well, TmpegENC seems to take quite a while to encode something that already is an MPEG. But ill take a look at the "author" one you are talking about. I think I only have looked @ the original Tmpeg.
    I guess I am looking for something where you just say , I want chapters 10 minutes or 5 minutes a part. Here's the cool menu I want with motion thumbnails, and then "go" make it!
  4. Nerovision Express does what you want.
    Cheers, Jim
    My DVDLab Guides
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Don't get TMPGEnc (the encoder) mixed up with TMPGEnc DVD Author (TDA). They are two different programs for different purposes. TDA is very newby friendly and after a very brief learning period you will be able to produce exactly what you are describing. It is the #1 most referrred authoring program around here because of it's ease of use.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    TDA will be perfect for this.
    If in doubt, Google it.
  7. YES> I just tried out Tmpeg Author - THANK YOU! IT IS FAST -- 15 MINUTES For a 2 hour movie! w/cool motion chapters. That is 90% of what I wanted. Now for the other 10% ..
    ONE MORE QUESTION .. can I add BACKGROUND Music to the chapter or main menu?? (w/ Tmpeg DVD author)
    on another note...
    I am about to sue pinnacle for selling me Studio 9. I have yet been able to create a movie that works on a dvd player..
    thanx, Zepolli
  8. You actually got PS9 to make and burn a movie?
    You're 2 steps ahead of most
    Cheers, Jim
    My DVDLab Guides
