Dear All.
In short i want to watch movies on my Epson P2000 (Portable harddrive player).
I have ripped dvds to my harddive using DVDdecyptor.
I then used Dr Divx to convert to AVI.
The files play very well if I play the clip from the beginning.
However if I seek through the clip and then play, the audio goes out of sync by about 5 - 7 seconds.
Is there any solution?
I am complete newbie with a very simple mind so please type slowly.
Josh
I'll show you my method; maybe it will work for you.
Rip VOBs with DVD Decrypter.
Combine VOBs into a single MPEG-2 with VideoReDo
Open the MPEG-2 in VirtualDubMod, then save as DIVX
This is probably more complex than it needs to be, but in all my experimenting it's the method that's produced the best results.You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Thanks.
Will this get over my issue of out of sync audio if I seek forward or back whilst playing a avi file back on the P2000?
When I seek back and forward when playing the file on my PC there are no problems.
Josh -
I am trying to open a dv file using VirtualDubMod but i get this error
Could not locate decompressor for format dvsd (unknown)
virtualdub requires a video for windows (vfw) compatabile codec to decompress video. Direct show codec, such as those used by windows media player, are not suitable only "direct stream copy" is available
for this video
how can i fix it please ?
thank you -
This is called Threadjacking - start your own thread for new questions - it's really easy once you get the hang of it...Originally Posted by humbleboy
That dealt and done with, look here for a solution to your problem.
/Mats -
sorry for the Threadjacking i did not know
and thanks for the answer it works fine -
You're welcome!
/Mats -
there is an answer in another thread:
https://www.videohelp.com/forum/viewtopic.php?p=1357001#1357001
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 14:41 -
Audio problem in DVI to HDMI conversion
By sfurqan in forum ComputerReplies: 3Last Post: 23rd Jun 2008, 19:41 -
Audio very low after VIDEO_TS -> DivX conversion
By mistafro in forum ffmpegX general discussionReplies: 7Last Post: 28th Feb 2008, 19:42 -
Build 2.5.3200 - Successful AVI-conversion - Upside down image..
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 4th Oct 2007, 17:58 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 05:13
