    Feb 2002
    Hi,
    Is there a software that plays an AVI file?
    canada
    Feb 2002
    Thanks.
    I tried to play my AVI file with Windows Media Player version 10.0 and it failed (wrong codec). How do I find found what codec is needed for my file?
    Dec 2004
    Australia
    avi is a MS format and windows comes with its own avi splitter. As suggested though you are simply missing a codec and GSpot can tell you which one(s) so that you can install it. WMP10 should then work fine. I still wouldn't recommend using it though.
