Hi,
I want to convert my hi8 tapes to svcd. I'm considering the wintv-pvr. Is there a sig difference in quality and efficiency between the pci and usb version?
I already have a miro dc30plus card in the system but the time with tmpgenc is to long for encoding for the mass of my tapes. Can the 2 hardwares coexist?
For a few hundred dollars, I'd rather have a quicker solution and maybe save the long process for a few select 'masterpieces'![]()
Can the quality played on my stand alone pioneer 333 dvd to TV be as good as the hi8 played thru the sony camcorder? Would a Dazzle or snazzi be better? I understand I may need to demux in tmpgenc after mpegII cap with the wintv card (or usb) but that sounds quicker and easy. Using win98se but could use win2000 if it would be sig better. (pent III 866) with 256meg ram and 30gig ultrascsi drive.
Anyway, appreciate some feedback.
Thanks,
Jack
Results 1 to 1 of 1
DRM hardware solution needed for stream to HDD/DVD Recorder
By SkyerFlyer in forum DVD & Blu-ray RecordersReplies: 5Last Post: 20th Feb 2011, 05:32 -
Choosing Hardware and Software Help Needed
By The OrangeLemon in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2010, 17:05 -
Choosing Music
By Flaskpost in forum Newbie / General discussionsReplies: 13Last Post: 24th Apr 2009, 22:51 -
hardware solution for VHS restoration
By yatidharmananda in forum RestorationReplies: 7Last Post: 31st May 2008, 17:53 -
Best hardware mpeg2 encoder (under 700 $)?
By Speed Demon in forum Capturing and VCRReplies: 27Last Post: 6th Sep 2007, 10:01
