  1. I created switched menus for subtitles. To choose the proper menu I need to use vm command as a selector. I thought that pgc number for every vts menu is number of the menu (order that I created them) +1. But it doesn't work.
    Does anybody know thw tool where I can see pgc numbers and how?
  2. Member jeanl's Avatar
    Sep 2004
    CA, USA
    What tool did you use to create your menus anyway? That tool should let you do that!
    In any case, PgcEdit is an easy way to find out. It has a preview so you can see what's in a given PGC.
    Jeanl
    MenuShrink a free tool to shrink menus into stills with or without audio!
    DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
  3. Thank you for reply, jeanl!
    I don't see pgc numbers in pgcedit. At least, I don't know where to find it. When I open dvd and click Edit PGC button, I see PGCN=0, which is not true. So, I try to choose PGC sequentially in my project and after 5th attemp I found out the right numbers (3 and 4 started to work). But it's big waste of time.
    Can you tell me how to check PGC numbers of VTS menus using PGCedit?
  4. Member jeanl's Avatar
    Sep 2004
    CA, USA
    The PGC number is the number next to the language for example right of (en) in the image below.
    Jeanl
  5. thank you very much. I thought it might be there, but was not sure. Thank you a lot!
