Results 1 to 11 of 11
  1. Hello all ripped a dvd that's under 4.3gig. Can I burn just the movie part without authoring?? If so what exact files do I need ???
    Apr 2002
    The State of Frustration
    Which movie? Some of the newer ones have different copyright schemes.
    Hello.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    If you ripped it intact or used dvd shrink you should have these file types:
    ****.vob
    ****.ifo
    ****.bup
    If you only have the .vob you should rerip or use ifoedit to make ifo files. Then you need to burn the video_ts folder with the above files inside them.
    That's it assuming they're still dvd compliant - if you haven't messed with the bitrate/resolution they should be
    Kevin
  4. Yes took the vob's ifo bup files and burned them. My player reads an error when it first starts up then i push the play button a couple of times and it works. I think it should start right up like they do with dvdshrink. Now when I reauthor it with dvdshrink there is no problems. I just thought you could take all the files if they fit and bypass dvdshrink. What am I doing wrong???
  5. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    you need to keep the IFO/BUP files and also make sure you burn then as a DVD within a VIDEO_TS folder using a DVD burning software
    are you keeping all the files on the DVD or are you just grabbing some?
  6. Yes keeping all the files needed. Just tell me why it works in shrink veruses burning vob ifo bup directly.
  7. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    how are you burning them and with what software?
  8. Burning with nero.
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...as Video DVD? (If it's already <4.3 GB, I'd do a ISO read/ISO write copy with DVDDecrypter...)
    /Mats
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    It works in shrink because shrink knows how to burn them properly
    Try http://members.dodo.net.au/~jimmalenko/NeroExpress.htm and see how you go.
    If in doubt, Google it.
  11. Thanks I will give that a try
