A friend of mine has a copy of a movie that is on 2 disc. The files on the 2 disk are .dat files for the movie itself plus there are other directories that have small files in them. I want to make a copy of the VCD but I can't get it to copy on my 80min disc. It says there is not enough room. I used TMPGEnc v1.76 and converted the .dat file to a mpeg file and then used Nero to try to burn a copy. I drag the .dat file down in the lower box up the box that Nero built from my selections when creating a new job. It does its thing and then burns the cd but when I put it in my DVD, which will play VCD or SVCD the counter goes to the end and it just sits there it won't play. Am I doing something wrong or can I do a disc to disc copy using another software. Any help is greatly appreciated.
Many Thanks
Morgan
Results 1 to 1 of 1
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 17:17 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
