I have converted a bunch of TV shows to mpeg-2 elementary streams, and I can verify that they import into DVDSP 3 OK. My confusion surrounds how to tag the DVD and the video streams within it with respect to 16:9.
The DVD is meant for an in-car widescreen DVD player, therefore I've transcoded all of the files into 16:9 with letterboxing and using QT to decode.
Question #1
Under the Disc inspector, there is a field that says "Menu Display" and there are two choices, including "Force to Letterbox" and "Force to Pan-Scan". Is this in case I decide to play the 16:9 DVD on a 4:3 set?
Question #2
When I open the Track Inspector, there is an option called "Mode" that has four options including 4:3, 16:9 Pan-Scan, 16:9 Letterbox, and 16:9 Pan-Scan & Letterbox. Which should I choose, and how are they different?
Thanks!
Results 1 to 1 of 1
ffmpegX only encodes warning at beginning of movie
By kgplumb in forum ffmpegX general discussionReplies: 2Last Post: 29th Aug 2010, 09:07 -
Livetype tot DVDSP help
By whiff79 in forum MacReplies: 3Last Post: 14th Mar 2010, 10:23 -
encode a Keynote Quicktime movie to mpeg2 using ffmpegx possible?
By mkoehler in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2008, 10:16 -
I am creating a PPM format movie and want to display it w ffmpegX
By kesnermodoc in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2008, 17:00 -
Movie files created in ffmpegX won't open in QT Pro
By waterdog in forum DVD RippingReplies: 1Last Post: 7th Nov 2007, 18:35
