Hey guys, I've been converting avis for quite some time, but I can't convert them all of the sudden. I keep getting this error that says something to the effect of the media being unsupported. I tried divx 3.11a AND divx 4.0, and neither one works. How do I fix this?
Thanks,
Gol
I had the same problem, solution I used? raise your directshow to priority 1 under options-enviromental settings-vfapi plugin. I found 1(+) to be best since anything higher made encoding slower and divx playback wasnt working correctly (artifacting bad)
any media player can play an unpoined part of an avi file without error msg
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2008, 02:58 -
After reinstall of OS etc, Tmpgenc encoder can't support avi media files
By AORMan in forum Video ConversionReplies: 15Last Post: 2nd Feb 2008, 11:36 -
Error message when opening AVI in Windows Media Player
By gomer in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 14:53 -
How can I play avi files on a SD media card on my TV?
By KenK in forum Portable VideoReplies: 7Last Post: 13th Aug 2007, 05:04 -
Joining 2 avi files, error with audio streams, need help
By leinan in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 07:12
