Got an AIW 9600, a VCR, and TBC-1000. I'm trying to figure out what cables I need to connect all of this together so I can go VCR -> TBC -> C.Card. I will be using S-Video.
Now, I know I need 2 S-Video Cables to go from VCR to TBC and then TBC to C.Card. Do I also need 2 sets of RCA Stereo cables to do the same for my audio signal? Or do you even need to pass the audio through the TBC (ie can you skip the TBC and go straight to the cap card)?
One other thing: how short should my cables be? I ask because I wonder if the audio/video will degrade if they are too long.
Thanks!
You can connect the audio straight from the VCR to the Capture Card; the TBC-1000 only buffers the audio for multiple outputs.
Standard cable lengths should be fine; 3 feet or less I guess? -
Gotcha.
3 feet is what I was looking for anyway, but am having some trouble finding inexpensive (yet premium) s-video cables at that length.
Any good cable sites out there I should try (i'm looking at http://www.ramelectronics.net/ and http://www.cablewholesale.com/ )? -
Use 3 foot for VCR to TBC and 3 foot for TBC to Capture Card. That's for the video of course.
For audio use 6 foot straight from VCR to Capture Card/Sound Card.
Analog EQ in chain before cap in pc
By mammo1789 in forum AudioReplies: 4Last Post: 7th Apr 2012, 21:22 -
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 21:13 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
Recommended Chain for Hardware processors
By mbself in forum RestorationReplies: 6Last Post: 30th Jan 2009, 21:38 -
Selecting the right DVI / HDMI cables for a Graphics card and Monitor
By vhelp in forum ComputerReplies: 11Last Post: 9th Nov 2008, 08:34
