Could someone tell me how to lock my computer and set up a password to open it so that others will not have access to it without the password? I would really appreciate your help. Thank you.
Results 1 to 10 of 10
Thank You,
GolfNut -
You can set a password in Windows but it not very secure if you using Windows 95 or Windows 98.
I have a password set in my BIOS. No body can do anything with out the password. You can't boot up from a floppy or anything else or enter SETUP mode until the password is entered. It is most secure.
But don't forget it! You can't use computer without it!
Check your BIOS SETUP to see if it let you set password. -
In Windows XP:
'Start->Control Panel->User Accounts'
Click on "Administrator"
Click on "Change my password"
Set the password
click on the "Home" button at the top
Click on "Change the way users log on or off"
Uncheck the box next to "Use the Welcome screen"
Click "Apply Options"
When you turn it on it'll requre a password before it boots into Windows. You can also lock it when you leave your computer by pressing either:
'ctrl'+'alt'+'delete' and then 'enter'
or
'windows key' + 'L'
If you want to be even more secure, your BIOS probably allows you to set a power-on password. You can usually access the BIOS by pressing 'delete' right when the computer comes on. -
[quote="jackal70058"]You can set a password in Windows but it not very secure if you using Windows 95 or Windows 98.
Correct
Wrong - remove the battery and viola PW is gone...Originally Posted by jackal70058
I see your using XP - just create a "user" and set permissions and you're done..
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
[quote="makntraks"]
This trick is more effective with laptops.Originally Posted by jackal70058
If you really thinking someone is taking you computer apart then you may want to lock the actual computer case so it not as easy to open.
If it easy to open up, all they have to do is remove the HD drive and hack the Windows password at their leisure.
There use to be kits to do this but I don't know where to find them now. -
hack the harddrive? are you kidding?
all you do is pop the drive in to another computer and remove the security restrictions, takes a few minutes. -
This is where EFS comes in handy. :P
Nothing can stop me now, 'cause I don't care anymore.
How to run 2 computers off of one set of computer speakers?
By Denvers Dawgs in forum ComputerReplies: 14Last Post: 7th Feb 2010, 09:54 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 15:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
lost password to log on computer
By pantangs in forum ComputerReplies: 4Last Post: 5th Feb 2009, 13:51 -
Syncing camcorder to TV set or computer monitor?
By bourboner in forum EditingReplies: 2Last Post: 13th Mar 2008, 05:09
