I have been burning too many coasters because svcd2dvd puts cd2
in front of cd2, yes I have them in order in the folder.
Sometime I have no problem, but most of the time it reverses the
order.
Anyone know why.
Thanks for your time
TheBoz
I did snip out the information to shorten the log.
Starting SVCD2DVD: v1.51.2.0
Begin time: 12:57:49 PM
******** Ripping BIN images to get mpegs (VCDGear -fix)
VCDGear 1.76 final build 031225 coded by Dracore
(vcdgear@hotmail.com)
Testing and quality control by MACKerMD
Language: English
Version: 3.50 - Jan. 1, 2003
Translation by: Dracore
processing method :: (bin2mpg)
.bin src(In) -> F:\DVD\mpg.cd2.bin
.mpg dest(Out) -> F:\DVD\mpg.cd2.mpg
snip ------- info
Analysing File: F:\DVD\mpg.cd1.mpg
snip -------
-->Processing 2 mpeg files
############### New MPEG File ###############
File: F:\DVD\mpg.cd2.mpg
Type: VCD
Horizontal Res: 352
Standard: NTSC
Audio SampleRate: 44100
snip ----- info
INFO: [???] File F:\DVD\mpg.cd1_DVD.mpv looks like an MPEG
Video stream.
INFO: [???] File F:\DVD\mpg.cd1_DVD.mpa looks like an MPEG
Audio stream.
snip -------- info
(Total size: 564MB, Duration: 00:01:13, Rate(MB/Min): 458.75)
Analysing File: F:\DVD\mpg.cd1_DVD.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok
for you!
******** Creating DVD Folders...
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing F:\DVD\mpg.cd2_DVD.mpg...
!!!: GOP is not closed on cell boundary (may be non seamless)
STAT: Processing F:\DVD\mpg.cd1_DVD.mpg...
-->: DVDFolders creating table of contents
scanning F:\DVD\VIDEO_TS/VTS_01_0.IFO
(Total size: 1040MB, Duration: 00:03:23, Rate(MB/Min): 306.26)
============ Complete ============
============ Duration: 00:11:20
Results 1 to 11 of 11
Are they in the correct order in the VTS list?
From the walkthrough:
We now have 2 VTSs each containing the mpegs for the movie in question. Take note of the order of the mpegs in the VTSs as this will be the order in which they are authored. If you need to move mpegs around you can just drag & drop them:
Yes, as I stated I have them in order in the folder DVD. I have them as mpg.cd1
mpg.cd2
I only burn 1 movie per DVD, because I'm new at this. -
It doesn't matter what order they are in your folder. It matters what order they are in the VTS section of the program.
The VTS section has the 2 files in reverse order. Sooo I get a burn in reverse order, this I now understand. What I can't do is move them around as you stated, "drag and drop". It will not allow me to do this and I've tried it many different ways.
You need to rename your files:-
you have:- cd1.mpg
cd2.bin.mpg
i think the ".bin" is your trouble
atb
bill -
Originally Posted by Lit
Ok, have a look at: http://www.svcd2dvd.com/Movies/VTS%20drag%20and%20Drop.htm
Does that help?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
SCVCD2DVD doesn’t seem to like my system, I’m having one heck of a time with the drag & drop after many unsuccessful tries I was able to move the files in order. Shortened log follows, as you can see it still starts with moviecd2
Begin time: 11:43:02 PM
File: F:\DVD\moviecd2.mpg
Type: VCD
Horizontal Res: 352
Standard: NTSC
******** Demultipexing original mpg file -
ok. Can you post a screenshot of your VTS setup?
Lit,
On repositioning segments of movies:
Assume you have three segments in your VTS like this:
CD_2
CD_3
CD_1
Click on CD_1 and drop it on top of CD_2. This will place
CD_1 ahead of CD_2.
It took me a while to fiure out the proper way to move them around too -
This has definitely been a learning experience. After deleting and renaming files many times it seems to be in order in the VTS when it first appears, I’m not sure just why that is. I now know what to look for to see if all is correct. The tip of placing the file on top of the other is right on the money. Hopefully this will help someone else who may have the same problem.
Thanks for the help.
Lit
SVCD2DVD and then burning with imgburn fails
By baby2003 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2010, 13:57 -
mpeg1 in reverse?
By dullrazor in forum Newbie / General discussionsReplies: 5Last Post: 26th Nov 2009, 12:17 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 04:09 -
Burning MP3 onto CD - Software - Arrange files to my order
By UmmAddan in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2008, 21:48 -
Speed/reverse in iMovie HD
By ker-plop in forum MacReplies: 3Last Post: 1st Nov 2007, 07:31
