  1. I followed the guide on how to burn Vob files with nero, everything went well except when i went to burn i encountered this error ( DVD reallocation failed, the resulting dvd video files may not be playable ) Anyone ever have this problem before? I added all files to the video ts folder and none to the audio.
    These are the files I have:
    Video_ts.BUP
    Video_ts.ifo
    Video_ts.vob
    Vts_01_0.bup
    VTS_01_0.ifo
    VTS_01_0.VOB
    VTS_01_0.VOB
    VTS_02_0.Bup
    VTS_02_0.IFO
    VTS_02_1.VOB
    VTS_03_0.BUP
    VTS_03_0.IFO
    VTS_03_1.IFO
    VTS_04_0.BUP
    VTS_04_0.IFO
    VTS_04_0. VOB
    VTS_04_1.VOB
    VTS_04_2.VOB
    VTS_04_3.VOB
    VTS_04_4.VOB
    VTS_04_5.VOB
  2. Banned
    Sep 2004
    Inner Circle of Thought
    What version of Nero are you using?
    You do not need a guide to burn with Nero.
    Select dvd-video----add the files----and burn.
    It is not that hard.
    I suggest using the latest version of Nero, which is 6.6.0.6
  3. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    I often get this message if I tweak the ifo file with ifoedit before burning. Seems to happen most often if I don't use ifoedit on the same day that I created the ifo. So far, I have been able to ignore the message and burn anyway and not have a problem.
  4. it worked anyway, even with the error. Thanks
