Hi:
I have spent hours in this site searching for an answer to my question, however, no luck and I am still confused. So, there is no other option but to ask you (experts) about this.
The question is: If I encode my videos with TMPGEnc first to DVD and then author them with NVE, will NeroVision Express re-encode them again? I have read that the new version have a "Smart encode" option that prevent the files to be encoded if they are already compliant. Is this true?
I have also read that the MPG2 conversion is better if you do it with TMPGEnc than with NVE.
Thanks in advance for your help.
THX
NVE seems to re-encode everything, even if it's totally dvd compliant beforehand.
I don't know if NVE 3 has an option to turn this off or not.
Most of us use tmpgenc dvd author or dvdlab to author our stuff, and nobody seems to like NVE for much of anything.
tmpgenc does do a better job of encoding than NVE and keeps audio in sync MUCH better.Cheers, Jim
My DVDLab Guides
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2008, 23:45 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 00:17 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 10:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 07:00
