I asked a friend, while my DVD recorder was unavailable, to record a DVD-R of a documentary from a tv program. He did, by recording the 02h 05 minutes program on his Pionneer 520H's HD. Unfortunately, he does not record chapters, because he thinks there are jumps in the picture at the chapters points. I assured him that chapters do not cause jumps, to no avail.
He then copied the program from the HD to a DVD-R (at SP), after eliminating te extra 5 minutes at the end. The resulting disc shows 4 temporary - about 1/2 second picture freezes - during the 2 hour DVD, always at the same points.
Can anyone explain how to remedy this?
Thanks,
Yvon
N 45° 31' .949" L 73° 41' .047"
Do the freezes appear when played from the hard drive? Was it copied to DVD in High-Speed mode? The only edit was at the end and not where the freezes occur, correct?
What brand of media was used? -
Originally Posted by Frobozz
- Freezes don't show up when played from the HD.
- The copy was made in High-Speed mode.
- The only edit was at the end.
- Memorex DVD-R was used.
Thanks for answering.
YvonN 45° 31' .949" L 73° 41' .047" -
I'd test with a different brand of media. Memorex is not too reliable. It could be media incompatibility. Everything else shouldn't be an issue unless there is a defect with the Pioneer's DVD burner itself.
ADDITIONAL INFORMATION:Originally Posted by Frobozz
I found out that my friend uses a variable rate of compression: approximately 3 Mb/sec. to 7 Mb/sec.
The bitrate at the freezes is only approximately 3 Mb/sec. which is not enough compression to be rendered on the DVD players/recorders.
A DVD player should have no trouble with 3Mb/sec video. Have you tried this disc in other players or on a computer? Does the problem happen when played on the Pioneer that recorded it? I'd still do a test with a different brand of media. Yes, there could be some defect with the Pioneer DVR but one disc doesn't prove it.
Its most likely the dvd player cause i get the same problem after buying a new radio shack dvd player,different media doesnt help,just cheap crappy player.
PIONEER DVR-520H-S
By K_cin_az in forum DVD & Blu-ray RecordersReplies: 3Last Post: 12th Jun 2011, 03:18 -
pioneer dvr-520h please shuts off !!!!
By motin in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Nov 2010, 08:24 -
Pioneer DVR-520H Can't finalize.
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Jan 2009, 23:30 -
Pioneer 520H and the new digital age
By GeckoTX in forum DVD & Blu-ray RecordersReplies: 6Last Post: 7th Sep 2008, 17:59 -
Pioneer DVR 520H and HDTV
By WCM in forum DVD & Blu-ray RecordersReplies: 3Last Post: 12th Feb 2008, 14:38
