Hi:
I am trying to author some .VOB files with NeroVision to a DVD-R. The files are in Dolby 5.1 and I need to know if NVE will encode them to Dolby 2.0 (Since is the format it support with the plug-in) or it will use them as 5.1 (original audio)
I want my DVD with the 5.1 audio. So, if the NVE will change them to 2.0, then what will you recomend to author them with the original audio?
I have also read that you can use DVDShrink to do it, if you create the .ifo files with IfoEdit. Are there any guides that can help me to do it with this method?
Thanks for your help.
Rey
Originally Posted by ranma_st
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
Dolby problem in Nerovision 3
By SuperJman in forum EditingReplies: 1Last Post: 3rd Dec 2008, 04:13 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42
