I have been trying to update some of the drivers on my system but have been getting an error with certain one's (the one's i need the most) and have found out that it is related to this:
http://support.microsoft.com/default.aspx?scid=kb;en-us;324767
Now it tells me how to fix the problem which is good but my problem is i can't find my XP disk!
Is there another way in which i can obtains the files?
Results 1 to 12 of 12
No it will roll everything back to a date when everything worked like it should.
ah well thats the problem i don't know how long ago that was cause i've only jst discovered the problem
Well its still worth a try,Go back as far has you can to a date that you know wont mess with your programs or Files,Other then that not sure what you can do without the XP disc,What are the files you are missing?
Moving to the Computer forum ...
Should'nt anyones XP disk be able to help him as long as his installed version of xp has a good product key?
Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress? -
As long as it is the same version and he puts in the same key, yes.Originally Posted by BobV
have you check the I386 folder on your C drive to see if it has a copy of the missing files? If it does just use your C drive letter instead of the CDROM drive letter.
Also you can try running the system file checker.
go to start>run and type sfc /scannow and click OK
Two .mp4 files - corrupted/damaged? - help
By swalk in forum Newbie / General discussionsReplies: 12Last Post: 15th Feb 2011, 22:40 -
MOV files damaged (but play fine in VLC) -repair how?
By tigrr in forum Video ConversionReplies: 9Last Post: 4th Feb 2011, 15:34 -
Any New Software that fixes damaged MTS files??
By deanna_v in forum MacReplies: 3Last Post: 1st Sep 2010, 03:33 -
Converting Damaged VHS Tapes to Files on a HDD
By RhoXS in forum Capturing and VCRReplies: 5Last Post: 20th Feb 2010, 08:40 -
Recovering damaged dvd files FYI
By Starman* in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2008, 10:32
