Hope this is the right place to post this question.
I bought my Pioneer a few weeks ago and at first it seemed fine but yesterday I had problems burning DVDs and I'm trying to work out if the burner has failed.
I have the Pioneer [firmware 1.18] as the master on my secondary IDE and my LiteOn LDW-851S [firmware GS0P] as secondary and I'm using 80 core cable. This was the recommended setup from the supplier.
The "problem" first showed when I burnt a DVD with CloneDVD2 and it said it had completed correctly but when I tried to play the DVD back it wouldn't play. When I checked the disc it had evidence of burning near the spindle but nothing else. I then tried to check the disc with kprobe2 but that wouldn't even scan the disc.
I then tried burning another disc, of the same sort, with RecordNow 7 and had the same result.
I then tried an Imation DVD-RW which I had previously burnt with the drive only a few days before and again it failed, but the same disc, with the same image file burnt OK on the LiteOn.
I then checked the properties of the drive in Control Panel and it only showed it as a CD-Drive and autoplay didn't show DVD Movie as an option.
This morning I checked the IDE cable before starting and it seemed OK but now I find that Control Panel correctly shows it as a DVD-RW and I have the DVD Movie option back in autoplay.
I've read somewhere that the visual change from "CD-RW drive" to "DVD-R drive" or vice versa is ONLY cosmetical...whatever that means.
I can't say that I've noticed this sort of change before but then I haven't been looking for it either.
I'm intending to play around burning some DVD-RWs today to see what results I get, and I will now be monitoring the way the burner is reported by XP (XP Pro+SP2) and see if it changes from a DVD-RW at any stage. I also thought I would try burning some CD-RWs as a comparison as I've read elsewhere on the forum that the burners have two lasers, one for CD writing and one for DVD writing and wonder if this is the problem. is there any FREEWARE software for testing the lasers?
The burner is still under guarantee but I don't want to contact the supplier until I'm sure there is a fault.
In the meantime I'd appreciate any comments/help anyone can give as I'm completely baffled at the moment.
Results 1 to 1 of 1
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th May 2010, 00:59 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Video Not Working Properly
By RamEEz in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2008, 20:23 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
