Is it possible to get a VCR and connect it to a canopus ADVC 100 or 300 unit then connect it to a stand alone DVD recorder, so as the Canopus can filter,improve the analog signal before recording the final output to the DVD Recorder?
Or will it only work when connected to your computer and you convert VHS to DVD that way?
That's not the purpose for the ADVC, unless you have a need for analog to digital conversion you don't need it. Only the ADVC 300 can "enhance" the video. It has a line TBC. Using the 100 would not have any effect.
If your purpose for buying a ADVC is to improve the signal look into getting a regular TBC instead.
https://www.videohelp.com/forum/viewtopic.php?p=1115672#1115672 -
The ADVC-100 will improve the quality if you're talking about
removing m****vision while recording from the VHS tape.
I don't know if that's what you had in mind when you posted!
Karen -
Shadow57 wrote:[quoteThe ADVC-100 will improve the quality if you're talking about
removing m****vision while recording from the VHS tape.][/quote]
not all ADVC-100 units can remove the macrovision...... -
I'm curious if mine works, it's thew newest on the market. What do you do turn it on and hold the input switch for 15 seconds or something like that?
The DVD recorder has similar hardware to the ADVC-100. Both will decode NTSC or PAL to YUV and A/D to a digital stream. The DVD recorder will encode straight to MPeg2.
The ADVC-100 will convert to a DV stream and will transfer that through IEEE-1394 to the DVR (assuming it has IEEE-1394 in) The DVR would then convert the DV stream to MPeg2.
You would need to test which alternative decodes NTSC/PAL better and which has overall superior performance.
The ADVC-300 has additional benefits inluding limited TBC and proc amp that may prove a benefit.
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Capturing with canopus advc 300
By blacksheepdownunder in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2010, 08:20 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 01:23 -
canopus advc 300 macbook pro
By petoo2 in forum Video ConversionReplies: 0Last Post: 9th Dec 2009, 19:29 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 08:15
