I use a plextor m402-u for conversion directly to mpeg-2, which is great. HOWEVER, it only creates NON-INTERLACED MPEG files.
I would like to use Studio to make my disks and Studio gives me an error when I open my captured MPEG that "NON-INTERLACED video is not supported". Apparently you can only edit interlaced video.
So I would like to get a program to convert non-interlaced mpeg files to interlaced. Any suggestions ?
Also - I have heardd the studio 9 can only handle up to 2 hour mpegs. is this true? I have tried all the other packages, except for NEO DVD which may be what I need. If I can't do the conversion and use Pinnacle studio 9, then I just need a good, fast program to add chapters (nice ones!) and re-encode.
I don't know if that is possible without re - encoding...
La Linea by Osvaldo Cavandoli
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 22:09 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
Samsung VP-MX20 and interlaced H.264 / Pinnacle Studio
By agallo70 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 13th May 2010, 15:20 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 18:48 -
after conversion to mpeg2 gets interlaced
By forare in forum Video ConversionReplies: 32Last Post: 13th Oct 2007, 23:47
