im trying to extract a file that is over 4GB and i get this message (write error: only NTFS file system supports files larger that 4GB) what does this mean? why wont WinRaR let me extract the file(ISO)? i have 64 files that are 47.6BM and i open the first file with winrar and im trying to extract the ISO. do i need a diffrent program? any help would be great
Your hard drive is most likely formatted with the FAT32 file system. FAT32 does not support files larger than 4GB. Windows XP and Windows 2000 have the capability of using the NTFS filesystem, which does support files over 4GB in size. Windows 95/98/ME do not support NTFS.
If you are using 2K or XP, you could convert your drive to NTFS, however, I would advise a full backup before attempting this. To convert, you would have to use the command prompt (I'm not familiar with the method, sorry), alternatively you could use a program like Partition Magic.
***Once again, I HIGHLY RECOMMEND a full backup before attempting to convert to NTFS.***Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Type this in from the command prompt.
CONVERT C: /FS:NTFS
You do not need to backup. Everything will be fine.It will ask for that name in confirmation. Then it will ask two further questions. Reply Y each time to set up conversion to happen at the next boot, then restart the machine. (If you are converting a partition other than the operating system’s partition, you may find that it runs without rebooting.) After returning to Win XP, the hard disk will work for two or three minutes, tidying up. Leave things alone during this time. -
i have windows ME, so can i do what u said "CONVERT C: /FS:NTFS" or will i have to get windows XP? im going to get Microsoft Windows XP Media Center Edition 2005 and un install ME and install windows XP Media Center Edition 2005. will this fix the problem if i install Microsoft Windows XP Media Center Edition 2005? is Microsoft Windows XP Media Center Edition 2005 a good windows program? i dont know to much about this so any info would be greatOriginally Posted by bazooka
ME does not (as far as I know) support NTFS.
I am not familiar with Media Center Edition, but I would have to guess it supports NTFS. If you do switch, a fresh install would be best.
If your data files (video, spreadsheet, etc. on say E:\) are on another partion, you will have to either delete them (wipe out any data) and recreate them, or convert them (keeping data in tact) once windows is installed.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
NoOriginally Posted by dblue
Or some variation of xp like media center edition.Originally Posted by dblue
That is fine.Originally Posted by dblue
If you do not pick fat32, yes.Originally Posted by dblue
That is for you to decide. I tried media center 2004 and did not care for it.Originally Posted by dblue -
what did u not like about it? how much diffrent is it from me? what windows program do u have?Originally Posted by bazooka
I really don't use my pc to record tv programs. I removed my tv tuner card from my pc because my television is not more than 10 feet away. The main thing is it's designed to replace your television and other components.Originally Posted by dblue
It is meant to be the centerpiece of the living room. You may like it. I am not really heavily into convergence.Originally Posted by dblue
I use XP Pro.Originally Posted by dblue
extracting .flac files with WINRAR
By burgkev in forum Newbie / General discussionsReplies: 9Last Post: 20th Apr 2010, 18:39 -
winrar problem
By catonic2206 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2009, 12:27 -
problems with winrar
By kennyjunior in forum Video ConversionReplies: 1Last Post: 19th Nov 2007, 13:00 -
Splitting with winrar?
By chronic777 in forum Off topicReplies: 0Last Post: 17th Aug 2007, 08:17 -
Winrar error
By alintatoc in forum Newbie / General discussionsReplies: 17Last Post: 28th Jul 2007, 07:04
