From what I understand a VCD should be able to be played in a standalone DVD player as well as a CD-ROM computer drive. I have a CD here that a fellow wants copies of to distribute for pulicity purposes. He said it is a VCD however it will not play in any of the 3 standalone DVD players I have, however it does play in my computer drive. There is an autorun file in the root directory.
I used Nero 6 and tried creating both an SVCD and a VCD. All went fine and it plays in my standalone DVD players, as well as my DVD writer with Power DVD however does not seem to want to play in a CD-ROM computer drive. There is no autorun file on the disk. I tried playing the MPG file that is on the disk with Windows Media Player and it would not play.
Could someone please help me out as to what I need to do to create a VCD or SVCD that will play in both standalone DVD players as well as CD computer drives.
I should also mention that I tried EasyVCD and after about 20+ hours of encoding it launched TMPGE which said my trial period had expired. I selected OK and it came up and said aborted by used so that was a wasted 20 hours.
Thanks for any advice you can offer.
Results 1 to 24 of 24
First and foremost....As with everything else (even DVD -/r) there is no 100% gar-run-tee it is going to play in every standalone, pc, dvd-rom drive etc.
This is just a fact of life that some machine love em and others hate em. It could be as simple as a media issue (your machine doesn't like TDK cdr but will work great with FujiFilm cdr) but the guy next door is totally opposite from you.
Since its VCD, why re-encode and everything your doing when you can very easily just copy the disc using the tools you already have?
Since this guy wants copies, and assuming this is all legit, just do a standard disc copy. If your problem child machines do infact support playing VCD , then it becomes a matter of finding the 'right' media to burn to for that par-tic-u-lar machine.
This site has an excellent database on players and what they do/dont support. I suggest you look in to that, check your equipment to make sure it supports VCD (true VCD/xvid/etc), then hopefully hunt & peck for the right media to burn to.
About the only other thing I can think of is he is saying its a true VCD (which your player might support) but its enfact encoded as xvid which your equipment doesn't support.
Sabrowww.sabronet.com - It's all you need...to know -
Opps, ment to say I'd do a disc copy on the copies you got to work without the autorun file on them. Then since they are working in some try different media brands.
Originally Posted by Sabro
Maybe I am just out in left field as to how VCDs are supposed to work but I am sure confused at this point.
When you create a VCD are there any files created in the root directory and what folders are created? Do they automatically run when you put them in a CD-ROM computer drive and play in at least some DVD players?
I have to make sure the copies I give him will work in both standalone DVD players as well as CD-ROM drives. I know I cannot guarantee that the VCD will play in every single standalone DVD player however if it plays in mine and his then at least I have fulfilled my obilgation however at this point I cannot get any of the ones I have created to play in a CD-ROM computer drive. They will play in my DVD writer but not my CD-ROM drive so either something is missing from the disk or I am doing something wrong or missing something.
Thanks -
Been awhile since I've done the VCD deal since moving on to DVDs, however did tons of em awhile back.
Basically from what you have said you was given a non VCD complaint mpg file which you encoded to vcd complaint. Don't quote me here 100% on the specs, but that VCD complaint file is still an mpg just with vcd extentions and various other files/directories that will let your dvd player reconize it.
I have never once, in my many vcd creations, had a vcd 'autorun' when using it in a pc's cd-rom or dvd unit, but it does autorun in my standalone dvd player (APEX AD1110-W) just as a normal dvd disc would.
I forget exactly why but thats just the jist of things, however, you can still play the vcd in your cd-rom on your pc by going to the MPEGAV directory on the disc and associating/clicking/running/open with on the AVSEQ01.DAT , AVSEQ02.DAT etc files.
Depending on how you've encoded, these DAT files are the original mpg(s) file with vcd extentions and will run on the pc cd-rom just fine.
If you ever want to reencode the dat file etc, be sure to always bring it back to the original mpg file by either stripping the vcd extentions out or reusing the original non-vcd complaint file. A vcd complaint 'mpg' is not the same as a normal mpg, although it will still play as one thru media player etc.
Get the disc to run as normal in your standalone dvd players, then slap the disc in to the cd-rom on your pc, go to the MPEGAV directory and click on the DAT files....should play just fine depending on how your system is setup (ie. should launch mediaplayer or your favorite viewer by association).
Hope this helps some.
Originally Posted by jackedup
In an SVCD it is a .mpg file inside an mpeg2 folder that you want to play."Art is making something out of nothing and selling it." - Frank Zappa -
Thanks -
This just might answer the autorun question - > https://www.videohelp.com/autorun.htm
Originally Posted by ZippyP.
/Mats -
It's been quite a while since this was discussed much, but at one stage there were a lot of threads about making (non-standard) VCDs which would play in most DVD standalones, but also autorun and start to play if you put them into a CD-ROM drive. (Some people suggested that you put a media player on the CD which launches itself.)
I'm not sure if it's a great idea or not, but if you do a search you might turn up one of the old threads. I'll have a quick look and see if I can find one of them. [edit] - sorry, I missed Sabro's post with a link to the autorun page, which covers most of that. [/edit]
Of course, you then get into the problem that what works on a Windoze PC won't work on a Mac or Linux machine, and even differences between the different flavours of Windoze.
As far as I recall, you may be able to author a standard VCD and then (depending on available space) place an un-authored MPEG1 mpg file outside the VCD file system in the route of the disc, perhaps with a readme txt or html file. MPEG1 is arguablly about the closest you'll get to a 'universal' standard for computers of all persuasions.
That would probably be what I would try and do if I was aiming to create a disc with the best chances of working on anything it was put into.
cheers,
theDruid. -
seems to youyr mate gave you a cd with a normal mpg file with a autorun bunged onto it, burnt as a 'normal data cd' and only some dvd players can play these the fact that you got a autorun file may confuse a dvdv player though,
the question is, is the mpg file vcd comliant, if nero says no, chances are its was created as a XVCD can check this by using easyvcd & try to insert chapters into it, if so good and creat a x-vcd without re-encoding. but you should check if your dvd player does support xvcd's.
no chapters , then use tmpg mpeg tools and re-mux them making sure the the type is 'mpeg-1 vcd' if the bit rate =1024kbs audio 224, any thing else its a xvcd so set type 'mpeg-1 vcd non- std'. create a vcd using easyvcd.
a vcd won't auto play, unless you try in xp when you first insert it it asks you how to open it?
2nd case the mpg is actually mpg2.... hum can't say much look up svcd!!! -
If the aim is to distribute this disc for publicity purposes, I would avoid XVCD (non-standards compliant) as it's very likely to reduce the percentage of machines the disc will work in properly.
If you're trying to make a disc that will play in as many computers / standalones as possible, I'd stick with VCD-compliant MPEG1. (As far as I know more DVD standalones play VCD than play SVCD/CVD).
If Nero tells you the mpg file on the CD you've been given is not VCD compliant, you may have to re-encode. What specifically does Nero say? (if, for example, it's only the audio stream that's not compliant, you don't want to re-encode the video).
Load your mpg file into VirtualDub and/or MPEG Properties and look at file information. The specs for VCD are on the what is... VCD page (link in the top left). Post a screen grab of the info if you want help.
If your file is not VCD compliant, you may want to ask the bloke who gave you the dics if he still has the source video - re-encoding the mpeg file will degrade the quality.
If you do have to encode again to get to VCD-compliant MPEG1, I wouldn't use Nero to do it (I think we've said this before Mats) - the basic free version of TMPGEnc is a very good encoder for this purpose.
cheers,
theDruid. -
Originally Posted by theDruid
/Mats -
Originally Posted by mats.hogberg
As I have a number of clients who don't want to shell out the bucks for a DVD player or refuse to advance their technology, I still do quite a number of VCD's. Here's the scoop:
Look to the left at the What Is sections for VCD & SVCD. It shows what the disc structure should look like. You can compare your original with that.
Also, contrary to what most of the above posters have said regarding AUTORUN, you CAN/MAY easily have a VCD autorun on a PC! There are a couple of things to think about here...
If you put an autorun (which you'll have to create the files manually), you need a player app. Does this player app need to make use of VCD 2.0 PBC features (menuing, branching, stills, playlists, etc)?
If not, create a batch file that will use the correct Windows Media Player for your system, and create an ASX metafile to direct the player to the AVSEQ##.DAT file(s).
If yes, you'll have to incorporate a VCDplayer app (such as Roxio's VCDPLAY.EXE) on the disc and have the autorun launch that.
Do you really want AUTORUN? If you incorporate autorun, but your customer's computer already has WINDVD/POWERDVD loaded and waiting for discs, you'll end up with a conflict because both the DVD player app and your autorun app will be trying to access the same media at the same time.
Look at some of my past posts on the subject for more info...
HTH,
Scott -
From what I remember, the TMPGE included with EasyVCD should only complain (time expired) when using it to encode to (S)VCD since only encoding to MPG2 is time limted without reg..
You should still be able to use EasyVCD to create MPG1 (VCDs) without TMPGE problems.
Hello,
I don't think anyone mentioned this in this thread yet so here it goes...
Some settop dvd players will NOT READ CDR discs. But they WILL PLAY CDRW discs
My sony dvps360 is just such a player. Won't play cdr no matter what but plays cdrw like they were pressed factory discs. It has to do with the wavelength of the laser and opacity of the rw discs from what I understand. The dvd players that read the R discs are calibrated properly to do just that...
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
mpg creating
By nighthawk2018 in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2009, 18:23 -
*Creating* AVCHD
By qabi in forum Video ConversionReplies: 2Last Post: 8th Dec 2009, 02:03 -
Error creating VCD
By maruz in forum ffmpegX general discussionReplies: 4Last Post: 17th Oct 2009, 06:42 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 12:05 -
Creating Movie
By Adarsh2211 in forum Video ConversionReplies: 2Last Post: 28th May 2007, 22:42
