I'm looking for a PC card that can do both compressed (most likely MJPEG) and uncompressed component capture. On a Mac my choice would be an Aurora IgniterX but I don't know as much about the PC options. My budget is $500 or less. I'm willing to go with older products if the price/performance ratio is right.
I know the Decklink SP will capture component uncompressed. I've owned Pinnacle/Truevision Targa 2000 cards in the past. Is there anything else I should be looking at? I'd rather not shell out money for two cards and I'll bet there are lesser known options out there that would fit the bill.
Good HDMI or Component Capture Card for Game Consoles?
By jargus in forum Capturing and VCRReplies: 18Last Post: 26th Jan 2011, 10:37 -
HD capture card, component inputs, record to PC?
By BOMOON in forum Capturing and VCRReplies: 9Last Post: 27th Dec 2009, 16:29 -
Card for capturing HD Component Signal
By peez in forum Capturing and VCRReplies: 4Last Post: 10th Nov 2009, 09:42 -
Trying to find Capture Card - w/ Component input
By tS_veXed in forum Capturing and VCRReplies: 63Last Post: 21st Nov 2008, 07:08 -
Capture card with Component (RGB) Input and 16:9 Support
By edt in forum Capturing and VCRReplies: 21Last Post: 27th Jun 2007, 09:58
