  1. hello everyone,
    A while back I purchased a refubished Gateway AR-230 from a liquidator that sells off of ebay. At first it worked pretty good but now the thing wont read any disk I put into it, including your everyday DVD movie. I contacted the seller and they said it came with a full manufacturer warranty and that I should contact them first. However, before I call I have some questions.
    1. How long is gateway's warranty? I looked all over, online, manual ect and it isnt mentioned anywhere.
    2. I installed Lite-on's 1163 firmware upgrade on the machine and as you all know all the graphics say lite-on, did I void the warranty doing this? If so, I've had no luck getting it to flash back to gateway's version, is it possible?
    3. The seller did send me a reciept for my purchase, however, is this a valid proof of purchase for gateway to accept?
    I know I'm asking a lot of questions here but if anyone knows anything about this stuff please help me out, I really appreciate it.
    Thank You!
  2. :::bump::::
    I talked to gateway and they said that they'll take it back but I still need to bring back the gateway firmware. Does anyone know how to do that??
