I have a batch of 8mm tapes recorded on a Canon from 1995 or so to around 2003. Sometime around 1999 my family discovered while viewing a tape that we just filmed that the audio wasn't coming though normally...when you hit play, the sound would start at normal volume and then gradually (but quickly) fade away. It becomes so soft that you have to put the TV's volume to max just to *faintly* hear it.
At the time, we thought that the camcorder's audio out jack was just burnt out. So we continued to use the camera...
In 2003, we bought a new 8mm camera and playing those tapes did the exact same thing...the audio would fade away into nothing!
We then tried to play some older 8mm tapes that had been recorded with the canon camcorder BEFORE we had started having audio problems. Lo and behold, the audio was perfect! Sound was perfect, didn't drop out or anything.
So it seems like something happened to the camcorder that caused it to mess up the audio on tapes from a certain point in time onward...
Recently, we found an old Canon on eBay that was almost the same model as ours. When we tested the "messed up" tapes on this replacement the sound would play! It doesn't perfectly (and actually the audio kind of drops out very very briefly every so often), but its coming through at least.
Sooooo....what happened? And why will the replacement canon we bought play the audio?
More importantly, is there something out there that might fully restore the audio (since it still drops briefly)?
Originally Posted by anitract
Best way to convert analog 8mm tapes to digital
By charliedog in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2011, 02:15 -
Converting old 8mm tapes to digital..help!
By MrMister007 in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2011, 22:59 -
archiving 8mm and dv tapes to recorder
By rikit in forum Newbie / General discussionsReplies: 7Last Post: 23rd Mar 2009, 17:05 -
Help with old 8mm camcorder tapes
By AmandaBMidlands in forum Portable VideoReplies: 2Last Post: 11th Nov 2008, 08:43 -
Advice on recovering old 8mm tapes
By VK4AKP in forum Capturing and VCRReplies: 4Last Post: 27th May 2008, 10:57
