Results 1 to 19 of 19
  1. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    2 ethernet card in 1 PC
    can i use two network card (Ethernet) on my PC in our university LAN...my PC is on XP SP2, and i want to install two ethernet network card in my PC....is this possible?
    hacking the Net using typewriter :D
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Yes
  3. Member Soopafresh's Avatar
    Jan 2004
    There's a registry tweak you have to do to allow both cards to have the same IP address, if that's what you're going for.
  4. I run two on my work machine without any issues.
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  5. Banned
    Sep 2004
    Not if you have a router.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    done all the time for connection sharing and firewalls runing on a pc
  7. and for reduntancy (automatic fall over) in servers
    Originally Posted by jagabo
  8. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    how can i make an application, for example firefox, to connect to the internet using the ethernet card 2 and my ftp client, cuteFTP for example, to use ethernet card 1 at the same time? is this possible?
  9. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    i want to use ethernet 1 for browsing the net and ethernet 2 for connecting to our FTP sever...is this possible?
  10. Member Soopafresh's Avatar
    Jan 2004
    Yes, but you'd be better off combining the two for aggregate bandwidth - 200 megabits per sec rather than 100.
    "Quality is cool, but don't forget... Content is King!"
  11. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    how will i do that?
    it is not important to me if i will divide my bandwidth...what is important to me is i will be able to assign to which ethernet card should an appication like firefox will use in connecting to the internet...any application that can do this? or tweak to the regisrty?
    how will i do it?
  12. Член BJ_M's Avatar
    Jul 2002
    Canada
    you want two different IP's ? or what
  13. Banned
    Apr 2001
    Calgary, Canada
    how will i do it?
    You can't arbitrarily assign an app to use a particular NIC/gateway unless the app supports it, otherwise it's controlled by the OS at a low level - it's called binding. And unless I'm mistaken, FireFox does not have this ability (and most client-apps don't).
    You could route your app(s) through another tunneling-app, but FAIK, no such app exists (yes, I know there are ssh-tunnels etc for a WAN, but nothing specific to these requirements of a tunnel on localhost).
  14. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Why would you really need to use bandwidth aggregation, unless you're moving a lot of large files internally? His connection is more than likely WAY below 100Mbps.
    Nothing can stop me now, 'cause I don't care anymore.
  15. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can do this if you run a virtual pc (vmware) .... the virtual pc can be assigned to one nic and the real os to the other .... ive done this myself , in fact you can run them both through 1 nic with two different IP's each connected to a cable modem
  16. Member Soopafresh's Avatar
    Jan 2004
    http://www.winguides.com/registry/display.php/951 Is the registry setting to network load balance the 2 nics.
    If you want to split the functions (web browsing on one card, FTP on the other), then you'll have to set up a local proxy server (easy to do) and point your web browser to use that. That way, you can specify which card is doing the http requests. Go to AnalogX.com for a free proxy server.
  17. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    thanks guys for the infos, i was googling the whole day yesterday for any info on this but i was not able to get a substanstial info.... your suggestion are way much better than those i googled ....ill try each one of them and see which one will work for me. ill try also to google from the infos youve given to research your ideas...if there is anymore suggestion feel free to add and thank you in advance...
  18. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    virtual pc is slow in my PC...maybe ill try the local proxy....any other good local proxy server out there where you can choose which NIC the proxy server will use?
    ill also try the proxy server from analogx
  19. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    i tried proxy from analogx but i can't find anything in the configuration where i can choose the network card to use...any other suggestions?
