Just wondering if anyone has any experience with this;
For a given media type/speed, does one writer burn better than the other? Better can mean whatever you want, but might also imply that the DVD will last longer or be more compatible in more machines, etc.
Closed Thread
Results 1 to 24 of 24
Someone will now doubt post a link or two regarding this. My comments are general comments.
Certain media have better compatibility. Slower burn speeds generally result in better compatibility. Certain writers are known to perform better, resulting in better compatibility.
As far as lasting longer, nothing lasts forever (especially if the dog gets hold of it). Your best bet is to always use quality media, and handle/store it carefully.
My 105 is fine.
No (not with RITEK 1x/2x DVD-R or Taiyo Yuden 4x DVD-R). My friend has a Pioneer 105 & I envy his burn quality. I have read that Pioneer 103/105/107 produce the highest quality burns (using DVD-R media). I wish my scans looked this good (they're almost as good). This TYG02 was burned on his Pioneer 105.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin
I never said that the 105s are bad. I just said that the burns on the 108s have fewer errors. I never said you should dump your 105 for a 108. If you are happy with what you have keep it. And I hate to point it out, but the scan above is not fantastic; good but hardly great. Again, if you are happy, keep it. Hardly garbage.
Still a few bugs in the system...
It is not worth debating as clearly you think my comments here are garbage. Any evidence I would provide would be countered by you with some evidence to support you position. The poster did not ask you to debate the benefits of buying a new drive over an older one. He just asked if the 108 burned better than the 105. If you are not open to the fact you might be wrong there is no point. It is always easier to be open to information when it is not reflective on your own self worth. You might notice that I have neither drive.Originally Posted by bazooka
My opinions are based on many scans I have seen on sites showing media burned on both drives. The scans could be forged, they might not be representitive of all the drives in existence, they could be skewed in favor of one bias or another. But based on all I have seen the 108 burns with fewer errors. Clearly you have seen something else.Still a few bugs in the system...
Read above. As to your scan, great PIF errors, not so great PI errors.Originally Posted by bazooka
I agree, time to be over this. I have no investment in the outcome and the interested parties have already made their decision. Anyhow, it is possible I am wrong if you look at PIF errors.Still a few bugs in the system...
I care because I've had high quailty discs burn successfully that wouldn't play properly for long. When I did the scans of my Maxell 4x discs at 4x, 8x and 12x, anything over 4x showed high errors despite reporting successful burns in Nero and playing well. A couple months later the 8x discs didn't play properly, never tried the 12x yet.Originally Posted by bazooka
"...That is garbage
I had the 105 and had no problems with it.
The only difference would be the time factor. ..."
Go to thefirmwarepage and review scans, you'll find many excellent scans from the 108 as well; and I have seen far better scans than those posted too. Bazooka, first you make an absurd post then follow it with an audicious comment like that, I find that very ironic. I don't necessarily agree with chas0039's comment on the 105 but he seems to have given some reasonable argument while I can't see the sense in yours.
High PI errors may affect the lifespan of a disk even with low PIF's afaik, and I know first hand that high PIF's (I had a couple peaks in 30's) may play fine while a disk is new but can fail in the near future. And btw looking at someone else's scans is pertinent, or the ones posted here are moot... :P
Mike
It was not absurd. You had crappy discs. I have hundreds of dvd's that were burned on my 105 that I used to have and guess what. They are still just as playable.Originally Posted by mikepos
My point is you cannot comment on what you have never had. I could say a corvette is junk, but unless I own one, then I am just flapping my lip. That was what chas0039 was doing.
The only difference between the 105 and others is the ability to burn both + and - and speed. The 105 was a 4x burner that would only burn dash discs.
I repeat, as long as it burns, it doesn't matter.
It doesn'tOriginally Posted by steve2713
You all are looking at it the wrong way. Look at the burner as if it were a car.
You cannot say one car is better than the other when they both drive you to the same location.
What matters is the media or in the car's case, it is gas.
What a useful topic.
I have something to add too....
Argue via e-mail, not the forum.Want my help? Ask here! (not via PM!)
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Pioneer-to-Bluray, BD-RE works, BD-R "cannot play disk" on Samsung player.
By spinningdisk in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 19:00 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
