In windows media player I get the following message:
Windows Media Player cannot play the DVD because a problem occurred while configuring copyright protection.
In PowerDVD I get:
TheTV Out port of your display card is not working properly.
This copy protected disc can not be played when the TV out function is enabled.
( I don't even have a TV out port on my card ).
I've removed and reinstalled both applications but get the same message.
I suspect this started after I installed a sound card driver, removing it didn't help either....
Any advice, apart from rebuild!, gratefully received.
Cheers
Russ -
That type of video card are you using?
Assuming you have a regeistered copy, you can access tech support here: http://www.gocyberlink.com/english/cs/support/new_site/support_index.jspGoogle is your Friend -
Make sure you have the most current drivers for your GeForce2 MX 100/200 video card:
Version: 71.84
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
well it might not be a good solution, but an easy solution would be to rip the dvd to an iso file with dvd decrypter & then mount the iso with daemon tools.. copy-protection free dvd.
sound like a codec problem to me. windows media player uses a third partie codec, hence PowerDVD. If PowerDVD fails to play it due to the codec, then wmp will also refuse to play it. Try an alternative palyer, like WinDVD.
Copyright and Child Protection when videoing
By IKnowNothing in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2011, 09:23 -
Putting a copyright on your dvds with Sony Vegas Pro 8.1?
By ingeborgdot in forum EditingReplies: 62Last Post: 11th Nov 2008, 19:08 -
Panasonic DMR ES20 . copyright protection? CPRM? FR mode no pause etc
By texas1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 2nd Mar 2008, 13:10 -
key exchange for dvd copyright protection
By repeatrepeat in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2007, 23:54 -
VHS Copyright protection
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2007, 05:57
