Results 1 to 28 of 28
  1. only_emo_kid
    Guest
    as topic says, because on my harold and kumar go to white castle, it tells me that.. does that mean it's not going to make the ISO of the backup correctly? Thx
  2. Member monzie's Avatar
    Nov 2003
    The Village
    Speaking 'inteligable' english helps.....
    ...are you talking about DVDDecrypter...or do we need a crystal ball to help you?
  3. only_emo_kid
    Guest
    thank u, i was in a hurry, so i edited it.. and yes dvd decryptor
  4. Banned
    May 2003
    Massachusetts
    It means... that dummy sectors... will be inserted...
    Ok, here's the part you missed:
    They'll be inserted INSTEAD OF BAD sectors!
    Does that help?
  5. only_emo_kid
    Guest
    yeah, but that means something will be missing right? like part of the movie?
  6. a type of copy protection
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  7. only_emo_kid
    Guest
    yeah, I know that. Just wondering if its going to remove anything from the dvd whcih i'd miss like parts of the movie? -Adam
  8. Member doppletwo's Avatar
    Dec 2004
    United States, Earff
    Inserting Dummy sectors means that it is working correctly.
    Removes only copy protection you get the whole mvie and any extra features.
    snappy phrase
    I don't know what you're talking about.
  9. only_emo_kid
    Guest
    Okay, Thank You
  10. Member monzie's Avatar
    Nov 2003
    The Village
    See it DOES help when everyones knows what your talking (writing) about......and I'd just got the old crystal ball and dowsing rods down from the attic......bugger.
  11. Banned
    Sep 2004
    Inner Circle of Thought
    The movie will still be intact.
  12. This is the fourth movie I have seen with this "sector protection" and the second in 2 days. It seems to be catching on.
    Still a few bugs in the system...
  13. Banned
    Sep 2004
    And dvddecrypter defeats it.
    The second disc of Aladdin used the sector protection as well.
    It was easily defeated.
  14. Member doppletwo's Avatar
    Dec 2004
    Yeah this new protection is very secure. It stopped me from backing up RE2...
    Well it stpped me for about an hour. LOL :P :b silly studios they thought they could stop backups.
    It just cracks me up.
    snappy phrase
  15. only_emo_kid
    Guest
    mine freezes at 95% on dvd decryptor it says its inserting the dummy files.. and i've got the latest decryptor, and on smart ripper it freezes on 94%
  16. Member doppletwo's Avatar
    Dec 2004
    VOB BLANKER should work , but Decrypter should worked too. VOB BLANKER is free also.
    Install VOB BLANKER don't change any settings Just select the input and output directories.
    Turn off any encryption breaking programs like DVD43 or AnyDVD before you run VOB BLANKER.
    snappy phrase
  17. only_emo_kid
    Guest
    Thanks for the advice and being serious with me. I'm trying vob blanker now. Thank You
  18. Banned
    May 2003
    Massachusetts
    A few people have reported that DVD Decrypter isn't working for them in this instance.
    Those people have something wrong with their system.
    No, I'm not kidding. If DVD Decrypter is being problematic for you in this instance, it might be time to figure out what's wrong with your machine.
    It's like the people that say that they have to run PowerDVD before they can rip a DVD... their machine is just retrograde.
  19. only_emo_kid
    Guest
    my decryptor freezes at 95% and smart ripper at 94% i've never had a problem before.. dunno. restarted multiple times, tried differ dvd drives.
  20. It is just possible that the reader could be causing the problems. Remember, my AOpen 1648 slowed WAY down during a couple of spots and I doubt the errors were random. Possibly the error correction cababilities of the reader could be the problem?
  21. Member doppletwo's Avatar
    Dec 2004
    Oh yeah I always forget to mention this part.
    VOB Blanker will output raw DVD files likes .VOB's and .IFO and such.
    Put all of the files that have been outputed (hmm that sounds weird) into a folder called VIDEO_TS and put that folder in a folder Named harold and Kumar.
    Use DVD Shrink and click open files instead of Open disc.
    If you don't make the folders I suggested DVD Shrink will name the .ISO file created the name of the folder where the files are.
    But you can change the name of the ISO and the volume in the ISO in DVD Shrink's options that appear when you press Backup
    snappy phrase
  22. only_emo_kid
    Guest
    no luck.. vob blanker froze and not responded.. my other computer with dvd decryptor stopped reading at 4% with 7 retries.. wtf never had a problem before
  23. only_emo_kid
    Guest
    also.. stops at 95% analysing with dvdshrink....
  24. Member doppletwo's Avatar
    Dec 2004
    Something is wrong with your computer have you installed any new hardware or software other than the stuff listed in this thread?
    I backed up Harold and Kumar using VOB Blanker because I think it was before the new version of DVD Decrypter was released.
    But nothing works for you I suggest taking it to a friends house. Try ripping it there.
    But the problem is definately specific to your computer.
    One of those techniques should have worked for you.
  25. only_emo_kid
    Guest
    no, i can rip any of my other dvds just fine... i just was working with school of rock, and it ripped fine. No other dvds have i had ANY type of problem with. my other computer, dunno why it froze on 4% its just stupid then..
  26. I'm having the same problem on Forgotten. I think it's just some of the new protection that they're doing on movies.
    "The fittest shall survive yet the unfit may live."
    --DEVO
  27. Member doppletwo's Avatar
    Dec 2004
    I have backed up plenty of movies with that protection RE2, The Forgotten, Friday Night Lights, Little Black Book and Harold and Kumar.
    I did all of them with VOB Blanker or the newest DVD Decrypter in File mode with the settings on ignore errors.
    Maybe thats it do yuo have ignore errors turned on in DVD Decrypter?
    But that still wouldn't explain why VOB Blanker isn't working.
    Hmm. Sorry I have to blame yuor computer.
    snappy phrase
  28. Banned
    May 2003
    Massachusetts
    The new protection involves the following:
    1. An area of the disc PURPOSELY has errors written to it. It's stamped that way.
    2. There are dummy cells which reference that area with the errors. This causes almost all rippers to crash out with a CRC error.
    The newest DVD Decrypter, as well as the newest AnyDVD, recognize this form of protection and skip over the errors, replacing them with dummy sectors.
    If the latest DVD Decrypter and/or AnyDVD doesn't work for you in this case, then there is either something wrong with your machine, or your burner is retrograde.
    Perhaps updating your burner's firmware will help. Or making sure that you're really using 3.5.2.0, not 3.5.1.0 or some earlier version.
