Sorry I didn't explain better;
I'm wondering if self-adhesive labels could be made that would be sensitive enough that existing burners could be used like HP's new ones- that the same laser that burns a DVD is powerful enough to affect some kind of chemical color-changing reaction in my theorized labels.
It just seems like a sham that we have to buy special drives and special disks, rather than just get a program and new labels to make grayscale labels in existing drives.
Results 31 to 36 of 36
You need extra HW for tracking the on the topside of the disk. The media has barcode like marks on the Inner hub that are probably used for tracking. The data side can use the ADIP and ATIP wobble for tracking but there is nothing on the topside for tracking. The drive has to know where it is at to write the label. I have an HP drive, when I get a scan of the finished media I will post it.I'm a little confused by this lightscribe stuff... why do I need a new burner? Doesn't the burner I have already have a laser in it capable of causing a chemical reaction?
RG -
How does a regular burner work? Aren't there 2 lasers- one to write and one to read? how does a regular burner know that it's writing to the correct place on the disk?
For a CDRW/DVDRW writer there are two lasers and both are used to write and read. The reason there are two is the wavelength of the laser needed to create the correct size spot on the recording material or Dye. Too read the laser power is decreased so no damage is done to an already written disk.
RG -
I've never had any trouble with my Yamaha DiscT@2. I use Verbatims for that. The Blue MetalAZO works well enough.
BTW-The firmware and/or hardware has to be able to handle the tighter tolerances required to make a pleasing image, plus the spacing of the "pits" is different than normal, requiring tight laser on/off timing control. I would guess that with those drives that have tight control already, it might be possible to do a firmware upgrade only. Otherwise, NEW DRIVE.
Scott -
Utterly silly, IMO. We go out and buy the fastest writers we can find, only to have to find special discs, flip it over, and have another go, to get a monochrome image on one side? What's wrong with sharpies?
/Mats
Looks like my benq 1620 may be dying, any writers burn 8x @ 12x?
By Denvers Dawgs in forum DVD & Blu-ray WritersReplies: 10Last Post: 27th Jul 2009, 13:05 -
Burn large MKV file onto several DVD-R disks
By fazza8 in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jan 2009, 07:28 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
What burner should i use to burn double layer disks
By Trident5 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Sep 2007, 06:51 -
Canon CD Lable Print
By chesterfield in forum MediaReplies: 3Last Post: 17th Jun 2007, 22:43
