BenQ and LiteOn will make HP's "LightScribe Direct Disc Labeling" burners.
The technology lets you burn/etch a label on the non-data side of the disk.
Full story at:
http://www.digitimes.com/systems/a20050120A7036.html
Results 1 to 30 of 36
Moving to Latest News forum ...
hmm
CMC?BenQ and Lite-On IT join CMC Magnetics, Taiwan’s largest producer of optical disks, as the only Taiwan OEM makers of HP’s LightScribe CD-R and DVD-R disks, according to the makers.
I hope it works better that Yamaha's Disc T@2.
We'll be right back after these messages from Binford! -
Originally Posted by freestyler
BWAAHAHAHAHAHAHAHAHAHAHA!!!
That's one sure-fire way to kill technology. Use junk.Want my help? Ask here! (not via PM!)
CMC CD-R is not bad media. That all that ships under the Verbatim brand name now. As far as Lightscribe goes, I have seen the labeling at CES and it is pretty decent looking technology. There are three issues that I see. 1. The labeling time for detailed images is ~ 35mins. 2. It is not color but grayscale. 3. The media prices are way to high for me to want a drive that has this implemented.
RG -
CMC CD-R is terrible media, always has been.
Sure it bad when you buy Hotan brand down at Frys. Thats the Low grade stuff that CMC sells too no name brand retail market. HP, Philips, TDK and Verbatim branded CMC CD-R writes well with all the writers I have tested it with. If fact it writes better then some of the older MCC 48X CD-R that I have.
I guess thats why Verbatim switched to CMC for all their CD-R.
RG -
if they switched - im sure it was because of cost and nothing else ...
It should. T@2 produced graphics by burning patterns into the unused portion of the data layer of the disc. That meant that the bigger your graphic, the less room you had for storage. If this is the same system I read about earlier, it uses discs with a special coating on the label side that reacts when hit by laser light. You write your data, flip the disc, then write your label. The biggest hurdle this scheme faces is getting enough manufacturers on board to make the special discs without raising the price 500%. I don't think many people want to go back to $1 burnable cds, even for snazzy printed labels.Originally Posted by Tool ManFight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
I thought T@2 was a good idea, hence I bought one
Trouble is, it's hard to find CD-R's these days with a dark enough dye.We'll be right back after these messages from Binford! -
They are going to have trouble getting people to buy one of these if it is only grey scale.Originally Posted by RAAGAAmanThis plan is so bad, it must be one of ours.
I thought we talked about this about a year ago. Only adds about $10 to the writer & the disks cost about ten cents more. But that pricing info is out of date too.
lightscribe will last in regular home conditions about 9-12 months according to websites they tested it.....is it worth it?....i do no think so...
and media will be expensive
when it will last at least 10 years in home conditions it will be worth it..not now...they need to make it better -
I just saw an ad on TV for HP that mentioned it's "DVD burners with Lightscrib". The one they showed in the tray looked like it was a bit more than just text, but then again, "individual results may vary".....
if it only lasted 12 months -- then all your dvds will last only 12 months because they are burned also onto the disk ...Originally Posted by deejay.2001
thats the dumbest thing i heard ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Maybe the difference is that the data is burned onto a different surface than the image....
thats right. The laser goes throught the disc and burns the text on label side, via a chemical reaction. HP has these already for sale in the pre-fab PC's at staples, etc. Sounds and looks great!
I saw some LightScribe Verbatim 52x CD-Rs at BestBuy last week. US $20.00 for a 30 disc spindle.
Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
I wish I could buy one of those drives, anyone seen one yet on its own?
it says on their site that you flip the disk over -- so it wouldnt go threw the disk ... havent seen it myself , so im not sure ..Originally Posted by mattyboy"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I'm curious, in any event. Of course, now that I have an Epson R200, I can already print on disks. I guess it depends on how they compare...
the epson sure will be more colorfull ... !
The disk is burned on the label side. You have to flip the disk over after or before you write the data side. You can write text or graphics. I have seen it is action and it is pretty nice and the images are sharp although grayscale only. Under normal storage conditions the labled disk should not have any noticible fading for 5 yrs. Of course if you leave it in direct sunlight or heat lamp it will fade. This would happen with any labeled disk.
Even the Verbatims I had sitting in my office window faded and I could not write them.
RG -
Usually, grayscale images are very good in magazines.
Hong Kong DVDs have had greyscale etched DVDs for 6 or 7 years.
The photo's and art works looks very very good, etched on mirror back disks.
I hope HP version is as good. -
this 'new technology' makes me laugh. Yeah its handy if you don't wanna buy a printer that prints onto disks etc. But thats about it. And why is this posted in the 'latest' news section!? i read about this a good 5/6 months ago.
Dan -
Read the original post, ie, "New News" as the 1st word in the subject says "Writers"
re: BenQ & LiteOn.
FWIW Mitsubishi makes LightScribe blanks. SEPT. 26, 2004 news:
Full PR @ http://www.verbatim.com/news/news_detail.cfm?news_id=21ED2D73-22D4-4DF0-AA1D5A06006A29C9Mitsubishi Kagaku Media Co., Ltd. (MKM) has announced an agreement with Hewlett-
Packard Company (HP) to produce and market LightScribe ink, CD, and DVD discs
developed in collaboration with HP.
With a LightScribe-enabled drive, consumers can use the same laser that burned
the data to the disc to make a distinctive-looking label for the other side of the disc.
MKM will market LightScribe discs, stampers, and ink.
The first-generation LightScribe discs produced and sold by MKM/Verbatim in 2005
will be monochrome. Second-generation LightScribe discs, which will be
able to accept multi-color printing, are under development. Although LightScribe
features have been added, the discs are also compatible with all current CD and DVD
standards.
Also at their site, a Jan. 6, 2005 PR. -
if getting picky on "old news" :
Posted: Jan 08, 2004
https://www.videohelp.com/forum/viewtopic.php?t=198254&highlight=lightscribe
Posted: Mar 09, 2004
https://www.videohelp.com/forum/viewtopic.php?t=210581&highlight=lightscribe
Posted: Nov 30, 2004
https://www.videohelp.com/forum/viewtopic.php?p=1117919&highlight=lightscribe#1117919"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I'm a little confused by this lightscribe stuff... why do I need a new burner? Doesn't the burner I have already have a laser in it capable of causing a chemical reaction?
Am I to believe that the laser in my new dual layer burner is not strong enough?
What's the power output (or however they measure it for lasers) of a standard DVD burner's laser vs. the laser in a laserjet printer? Couldn't someone just develop some self-adhesive labels that are sensitive enough for existing burners? Is anyone working on something like this? -
i bet your burner will not burn on the BACK of dvd's .
i heard some talk though of firmware updates to some recorders ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Looks like my benq 1620 may be dying, any writers burn 8x @ 12x?
By Denvers Dawgs in forum DVD & Blu-ray WritersReplies: 10Last Post: 27th Jul 2009, 13:05 -
Burn large MKV file onto several DVD-R disks
By fazza8 in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jan 2009, 07:28 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
What burner should i use to burn double layer disks
By Trident5 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Sep 2007, 06:51 -
Canon CD Lable Print
By chesterfield in forum MediaReplies: 3Last Post: 17th Jun 2007, 22:43
