I dotn know if this is the right forum to post this but i post it any way,,,,
I just bought my pioneer 108 dvd burner not more than a month a go and now this : http://www.supertechstore.com/pidvdulabuba1.html
pioneer 109? what the hell is going on,, god please help, should i change or stick with pioneer 108? should i keep pioneer 108 or exchange to pioneer 109?
Results 1 to 10 of 10
I would exchange it if it doesn't cost you anything
The only differance is DL and RW speed,it might be a year before we see that media(read:try to find 32x CD-RW).
I would keep the 108 because they're going to charge you shipping and a 15% restocking fee...that is if they let you get a refund. -
Who said it's going to be better??? Has anyone seen any reviews yet?
maybe not, but it's not worse....I think is a 108 with different firmware same as Nec 3500 VS 3520Originally Posted by Naith
i would keep the 108, unless you want to spend more, for something that you don't use
I still use my NEC 1100....which is a 2.4x for RW...don't matter if I wait 10 more min, it's good for a coffe break....
The 109 is different hardware from 108.
Would it be better to get the 109 or an LG since they both handle dvd ram?
COPIED OVER 600 DVDS SO FAR -
You said above: "The 109 is different hardware from 108."
I would like to know: the 109 hardware is better the 108? which is the difference? thanks.
Abit Fatal1ty AN8
Athlon 64 3000+ Venice socket 939
2x1gb ram Corsair Value dual channel
Radeon X800 D3 Gecube 256 pci-e
HD Samsung 80GB 7200 rpm
Power Supply Seventeam 420 w atx 2.0
Monitor LG Flatron 17"
Windows XP SP2
multiAVCHD - (RT) Invalid array index. Array is empty - Line 109.
By JackyWang in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Oct 2011, 09:53 -
NeoDivX 2008 3002.0.1.109
By zebbra in forum Newbie / General discussionsReplies: 5Last Post: 5th Aug 2008, 23:20 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 05:44 -
VideoInspector updated to v1.10.2.109
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 20th May 2007, 15:03 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 09:48
