For anyone who owns a Pioneer standalone DVD Recorder- does it have a 3 hour mode? In particular I'm thinking about getting either the 420 at Costco's or the 520HS.
Results 1 to 16 of 16
Thanks. I've already read all the reviews. My only question (which I missed if it was covered in reviews) is whether or not it/they (Pioneers) have a 3 hour recording mode.
It's 352x480, as well it should be at that bitrate.Originally Posted by syncWant my help? Ask here! (not via PM!)
I'm curious about these Pioneer recorders also. Am I correct in the understanding that using those 'MN' settings will not result in standard compliant DVDs, as in if I used the MN19 setting to record something to the HD, then burned it to a DVD, it would not be playable on most DVD players? Am I correct? The ability to go to 2hr 20min, for example, is really a nice feature instead of going straight to 3hr mode, but if it isn't compatible with anything, then it takes most of the advantage out of it for me
I must be confusing the 'MN' settings with the 'VR' mode I've read about somewhere, whatever the hell that is... I'm just confused now
steve2713
if you're in DVD Video mode and after recording finalise,
it is in DVD standard. -
The "MN" setting refers to Manual setting -- where instead of choosing a preset such as SP or LP, you "fine tune" it to the best quality for the length of your recording. (I always calculate the estimated program time MINUS commercials first, so I can get the best quality possible for the actual program content when burning to disc.)Originally Posted by steve2713
Panasonic Lumix DMC-ZS7 recording modes
By RL in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Oct 2011, 22:55 -
HD signal formats and recording modes
By ProducerHarley in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2009, 19:04 -
recording modes, when to use, and for what?
By dvnoob in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Oct 2008, 09:22 -
Sanyo VPC-HD1000 recording modes - to DVD
By haggisv in forum EditingReplies: 6Last Post: 24th Mar 2008, 20:29 -
DVD Player Compatible with 2004 Pioneer DVR 220-S VR Mode of Recording
By iloveamerica11 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Dec 2007, 12:14
