I've been following a guide to make good VCD's (one's which will play on an older stand-alone player, so no KVCD's etc), and it said to use Virtualdub to frameserve the .avi file. So i create a signpost file, named it x.avi, then tried to open it in TMPGEnc- it says " can't open x.avi, or file unsupported". What I'm doing wrong? And on a kind of un-related note, my WMP series 10 won't play .wmv files now either! Everything else works fine, but I recently installed an Xvid codec pack, so how can I check/manage my codecs?
have you setup virtual dubs frameserver previously where it will register its routines? you might have done that when you installed it.
Some people are only alive because it may be illegal to kill them -
Yeah, looks like you were right, I managed to get Virtualdub to frameserve to TMPGEnc, just have to wait for the results
Can anyone help me with my codec problem, it's annoying to have Windows Media Player 10 not be able to play it's own format (windows media audio/video). Would uninstalling and re-installing media player help? Or perhaps another codec? How would I check/delete which codecs I have?
just reinstall windows media player
Use media player classic to play the files,much better than wmp.
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 10:42 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 31st Aug 2009, 00:40 -
Subtitles won't show in TMPGenc
By knn03 in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2009, 22:12 -
How to frameserve this resizing algorithm to TMPGEnc?
By DRP in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 23:19 -
Frameserve from VirtualDubMod to TMPGEnc
By pchan in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 09:13
